DHCP Conflicts
dudadiesel
Is there a way to set the Asus 86U router so that only a certain range of IP addresses can be assigned via DHCP? I'm running into an issue where some static IP devices can get faulty power supplies and then end up in a fight with a DHCP device that decided to steal its IP address while the static one was off. MAC address binding isn't a good solution as there's over 64 static IP devices on the network. So I'm hoping I can just set the router to only pull DHCP IPs from a certain pool of IPs that I won't ever use for static IP devices.
Yes, that's basic stock functionality under LAN / DHCP Server / IP Pool Starting Address & IP Pool Ending address.
If you want to pick and choose which non-contiguous IPs are in or out of the DHCP pool, that's not so easy. But it all starts with limiting the DHCP pool away from the range of IPs you assign statically.
Well that was a stupid easy fix. And I even knew about this but for some reason thought it was related to all IPs allowed rather than just DHCP. It's under DHCP, duh! Thanks! All is well now.
