Entware dig can not run in 386.12
saccleo
i installed bind-dig from Entware, when i run dig in terminal, i got this
netmgr/uverr2result.c:101:isc___nm_uverr2result(): unable to convert libuv error code in udp_send_cb (netmgr/udp.c:802) to isc_result: -38: function not implemented
what wrong with this?
What router model is this?
What other features, options and scripts do you have running on it?
I had the same problem with the aarch64-k3.10 version of bind-dig. In my case it was just returning a Bus error message.
In the end I had to force remove and reinstall a lot of libraries to get it to work:
opkg --force-depends remove libgcc libpthread libc libssp librt libopenssl zlib libatomic libuv libnghttp2
opkg install libgcc libpthread libc libssp librt libopenssl zlib libatomic libuv libnghttp2
it does not work.
You're running a model that is no longer supported by RMerlin.
Are you using john9527's fork?
Supported models:​
Older platform:
  • RT-AC66U_B1 (same firmware as the RT-AC68U)
_B1, yes.
I also encountered the same problem as saccleo. I resolved the issue by reverting to an older version of libuv.so.1.0.0. I had an older version on a USB stick.
I am actively looking for new opportunities because the contract for the last job ended on 21st July 2023. https://www.garrigan.nyc
With the problem:
# nslookup www.google.com
;; communications error to 127.0.0.1#53: timed out
;; no servers could be reached
After replacing the file:
Server: 127.0.0.1
Address: 127.0.0.1#53
Non-authoritative answer:
Address: 142.250.80.36
Address: 2607:f8b0:4006:81c::2004
I tried the solution from ColinTaylor with the knowledge that the error messages were different. The problem remained.
libuv - 1.45.0-1
I determined the issue existed on a few Asus routers and I know I had updated packages within minutes of updating the firmware on the newest router.
The solution for me was to revert to an earlier version of libuv.so.1.0.0. I had an older version on a USB stick.
From the file libuv.control
Package: libuv
Version: 1.44.1-1
Depends: libc, libssp, librt, libpthread, libpthread, librt
Source: feeds/packages/libs/libuv
SourceName: libuv
License: MIT
LicenseFiles: LICENSE
Section: libs
SourceDateEpoch: 1648915757
CPE-ID: cpe:/a:libuv_project:libuv
Maintainer: Marko Ratkaj <markoratkaj@gmail.com>
Architecture: armv7-2.6
Installed-Size: 58639
Description: libuv is a multi-platform support library with a focus on asynchronous I/O. It was primarily developed for use by Node.js, but it's also used by Luvit, Julia, pyuv, and others.
model=RT-AC88U
wps_modelnum=RT-AC88U
webs_state_info_am=386_12_0
innerver=3.0.0.4.386.7_0
buildno=386.12
webs_state_info=3004_386_12_0
buildno_org=386.12
model=RT-AC87U
wps_modelnum=RT-AC87U
innerver=3.0.0.4.384.13_10
buildno=384.13
buildno_org=384.13
tcp 0 0 router1.home.local:domain 0.0.0.0:* LISTEN 11416/dnsmasq
tcp 0 0 ip6-localhost:domain :::* LISTEN 11416/dnsmasq
tcp 0 0 router1.home.local:domain :::* LISTEN 11416/dnsmasq
tcp 0 0 fe80::XXXXXXXXXXXXXXXXXdomain :::* LISTEN 11416/dnsmasq
udp 0 0 router1.home.local:domain 0.0.0.0:* 11416/dnsmasq
udp 0 0 ip6-localhost:domain :::* 11416/dnsmasq
udp 0 0 router1.home.local:domain :::* 11416/dnsmasq
udp 0 0 fe80::XXXXXXXXXXXXXXXX:domain :::* 11416/dnsmasq
Active UNIX domain sockets (servers and established)
In my case something else. After an entware update earlier this weekend, my logs fill with dig Tainted. (4 in a row for each program every hour) Not realy a big problem for me because Skynet and Diversion work as intended. After fresh install RT-AC86U_386.12.
So i did as you stated, remove and install the packages. I think it will work. Thanks Colin!
Update: Ah it didnt work unfortunately.
ep 11 19:05:36 kernel: dig[25992]: syscall 425
Sep 11 19:05:36 kernel: Code: aa0503e4 aa0603e5 aa0703e6 d4000001 (b13ffc1f)
Sep 11 19:05:36 kernel: CPU: 0 PID: 25992 Comm: dig Tainted: P O 4.1.27 #2
Sep 11 12:00:00 uiDivStats: Starting stat update
Sep 11 12:00:07 kernel: dig[13019]: syscall 425
Sep 11 12:00:07 kernel: Code: aa0503e4 aa0603e5 aa0703e6 d4000001 (b13ffc1f)
Sep 11 12:00:07 kernel: CPU: 1 PID: 13019 Comm: dig Tainted: P           O    4.1.27 #2
Sep 11 12:00:07 kernel: Hardware name: Broadcom-v8A (DT)
Sep 11 12:00:07 kernel: task: ffffffc013874040 ti: ffffffc0058ec000 task.ti: ffffffc0058ec000
Sep 11 12:00:07 kernel: PC is at 0x7f80101ee4
Sep 11 12:00:07 kernel: LR is at 0x7f800193a4
Sep 11 12:00:07 kernel: pc : [<0000007f80101ee4>] lr : [<0000007f800193a4>] pstate: 20000000
Sep 11 13:00:02 Skynet: [#] 23606 IPs (+0) -- 78866 Ranges Banned (+0) || 0 Inbound -- 23 Outbound Connections Blocked! [save] [2s]
Sep 11 13:00:08 kernel: dig[17380]: syscall 425
Sep 11 13:00:08 kernel: Code: aa0503e4 aa0603e5 aa0703e6 d4000001 (b13ffc1f)
Sep 11 13:00:08 kernel: CPU: 1 PID: 17380 Comm: dig Tainted: P           O    4.1.27 #2
Sep 11 13:00:08 kernel: Hardware name: Broadcom-v8A (DT)
Sep 11 13:00:08 kernel: task: ffffffc013890ac0 ti: ffffffc003ffc000 task.ti: ffffffc003ffc000
Sep 11 13:00:08 kernel: PC is at 0x7f8b91eee4
Sep 11 13:00:08 kernel: LR is at 0x7f8b8363a4
Sep 11 13:00:08 kernel: pc : [<0000007f8b91eee4>] lr : [<0000007f8b8363a4>] pstate: 20000000
May  5 07:05:07 lldpd[1218]: could not open either /etc/os-release or /usr/lib/os-release
May  5 07:05:07 lldpd[1218]: lsb_release information not available
May  5 07:05:07 lldpd[1222]: created chroot directory /var/run/lldpd
May  5 07:05:07 lldpd[1222]: /etc/localtime copied to chroot
May  5 07:05:07 lldpd[1222]: protocol LLDP enabled
May  5 07:05:07 lldpd[1222]: protocol CDPv1 disabled
May  5 07:05:07 lldpd[1222]: protocol CDPv2 disabled
May  5 07:05:07 lldpd[1222]: protocol SONMP disabled
May  5 07:05:07 lldpd[1222]: protocol EDP disabled
May  5 07:05:07 lldpd[1222]: protocol FDP disabled
May  5 07:05:07 lldpd[1222]: libevent 2.0.21-stable initialized with epoll method
@Sonyrolfy Try this:
opkg remove --force-depends bind-dig bind-libs
opkg install bind-dig
If that doesn't work you could resort to the nuclear option :eek::
/opt/etc/init.d/rc.unslung stop
opkg list-installed | /usr/bin/awk '{print $1}' | /usr/bin/xargs opkg --force-reinstall install
/opt/etc/init.d/rc.unslung start
Thanks Colin for your help! First code i tried from you did nothing unfortunately. The second made think. So before i go war with this router, I remembered a similar case a while ago with a script from YazDHCP, Tainted bladibla in the logs. I removed his script, and put reservations in vram again. Outcome: clean logs! So i just removed uiDivStats. Outcome: clean logs! So if more and more scripts must be removed (in my case) due to Tainted bladibla. Maybe i need a new router. Not really need one for my case, but..
Update: I tried your war script. After installing uiDivStats again. No luck, the log still fills with kernel: dig[20978]: syscall 425 again. So i removed uiDivStats for now. And clean logs! Also i think as a side effect with the Tainted bladibla that i couldn't log into the router anymore. The router is still working fine, but its like a old car dashboard now, just pulling the lighted small bulbs from engine service or ABS or whatever:) But it does the job. (for now) Thanks!
uiDivStats will no longer work anyway with the next Diversion update, unless it gets updated eventually.
A oke that's one thing less to care about (for me, for now). Diversion is great and cant wait to see whats new!
uiDivStats is an great tool for a clear visible overview. I hope uiDivStats will be updated then.
This fixed it.
opkg install --force-depends bind-dig
After:
opkg update
opkg remove libuv  --force-depends
opkg install libuv
Now: Log only messages more urgent than All instead to: Warning 😀
Is this relatively clean to do? I am still chasing my favorite problem, and may try this. Here is the problem I have:
After holidays I'll probably go to 12_4 version, and re-do Entware packages here. Don't want family to lose holiday internet, LOL
