Fiber ONU and Wireless router as Access Point Mode
conquer22
Dear All,
I am recently changed to Fiber and it's fantastic with less local ISP ping respond 3ms-5ms. My current setup is to have Fiber ONU on "WAN route" + NAT on and have it set 192.168.1.1 and DHCP. I connect Wireless router(manually fix IP 192.168.1.2 and have gateway back to 192.168.1.1) turn off DHCP and only set to Access Point Mode(Asus)
I assume my case is not double NAT, correct?
I have read many post about double NAT and to improve perfomance by making Fiber ONU as only set "WAN bridge" and let wireless router handles everything (Dial-up+NAT+DHCP+wireless)
May I ask for advice if it worth changing this new settings and would it improve overall performance.
I wonder if my current system is the way be
wireless device->access point->ONU->access point->wireless device
or should it be
wireless device->wireless router handles everything->wireless device
Many thanks
When you connect the wifi router connect it on the LAN port.
As for who should do NAT that depends on which is better. If the router is better let the router do NAT and your ONU can be a bridge.
Many thanks for reply. I thought changing Bridge mode is easy by just changing from WAN Route to WAN Bridge but it's not. Changes can not be applied as it prompt the current connection can not be applied as bridge mode. The So now I wonder if I need to delete the current route profile and create new connection as WAN bridge profile connect. but now I wonder what option i have to choose now and binding option?
Now, I have reset all ONU configuration and I'm not sure if I have to go back and turn off the DHCP and what option I have to change on the Working LAN port.
