Hi
I have an STB provided by my ISP and recently they released an update which makes it possible to install Netflix on it.
The problem that I have now is that if I set port 4 on my AC-U68 as an IPTV STB Port the netflix app can no longer connect to the Netflix servers but if I leave the port as a standard port I do have Netflix but no IPTV.
If I connect the STB to any of the ports on the ISP provided all-in-one modem/router both IPTV and Netflix work.
Does anyone know how I can use port 4 on the AC-68U for both IPTV and Netflix on the STB?
Thanks in advance.
ps. My ISP is Belgacom/Proximus so there isn't a profile available. I used "none" to enable IPTV on the AC-68U
Thanks in advance.
