I hope someone might be able to help.
I connect my Mac to the internet via a Belkin N router which has worked fine, and the router is also connected to my Xbox through one of the ethernet ports, again this works fine.
I have now purchased an Iomega ix2-200 2TB unit as my Mac HDD is quickly running low on space, and I also want the peace of mind of my data being backed up.
Unfortunately, the Iomega unit does not seem to want to work when connected to an ethernet port on my router. The 'wired' indicator on the router lights up for about 15 seconds, then turns off for 15 seconds when the connection is lost.
I can connect the Iomega unit direct to the computer and it works ok.
I wonder if anyone might be able to help. I have swapped cables and used different ethernet ports on the router but nothing seems to work.
Thanks,
D.
Thanks,
D.
