Have L2tp setup, and working
The IPSec I'm struggling with.
So I have IPSec working:
Proposal-sha1/aes256
Windows peers work with peer as sha1/aes256
iOS peers work with sha512/aes256
What I want to do is create 2 profiles 1 for Windows 1 for iOS but if I create the 2 types of peers then how do I specify which peer each client uses?
I've done loads of reading but can't get my head around it. Also how do I check the peer encryption as I can see no way?
Client IP is dynamic but I can use multiple dst addresses if this is the only way to segregate it
I'm also assuming that asus does not support IPSec as only connects via l2tp
Thanks in advance
Thanks in advance
