Linksys EA9500 and Roku Private Listening/Remote
Tahvi1
I have a Linksys EA9500 and often use the private listening feature of my Roku stick. But the audio was getting dropped about once an hour or so requiring the private listening to be turned off and on again. It's not really a big deal, but in addition to that, the remote would occasionally unpair from the stick and it was always a headache to get it paired again (multiple reboots + pressing the pairing button + fingers crossed). I then began to wonder if my router's tri-band "smart" balancing system (two channels, one ssid) might be at fault - perhaps if the Roku and the remote get put on different 5 GHz channels they won't communicate. So I turned off the second 5 GHz channel and have had no problems at all with the remote or private listening.
So my question is this: Was I correct about having the two 5 GHz channels in general, or is there a problem with the EA9500 router's implementation? In other words, if I were to someday get a different tri-band (or some kind of multi-band) router, would I experience the same problems and have to turn off the feature?
Smokindog Using Linksys MR7500 Hydra Pro 6E as AP General Wireless Discussion 2
