Hi Merlin,
In your builds, is there a way to mount jffs to usb drive like DD-WRT? I plan to install your latest build for N-66U tonight.
Hi Merlin,
Got another question for you. I was reading your "Iptables tips" at your github site. I want to force users to only use my specified DNS servers. Should I use the firewall-start or the nat-start location for that?
* User scripts *
These are shell scripts that you can create, and which will be run when
certain events occur. Those scripts must be saved in /jffs/scripts/
(so, JFFS must be enabled and formatted). Available scripts:
- services-start: Services are started (boot)
- services-stop: Services are stopped (reboot)
- wan-start: WAN interface just come up (includes if it went down and back up)
- firewall-start: Firewall is started (filter rules have been applied)
- nat-start: nat rules (i.e. port forwards and such) have been applied (nat table)
- init-start: Right after jffs is mounted, before any of the services get started
- pre-mount: Just before a partition is mounted. Be careful with
this script. This is run in a blocking call and will block the mounting of the
partition for which it is invoked till its execution is complete. This is done
so that it can be used for things like running e2fsck on the partition before
mounting. This script is also passed the device path being mounted as an
argument which can be used in the script using $1.
- post-mount: Just after a partition is mounted
Don't forget to set them as executable:
chmod a+rx /jffs/scripts/*
And like any Linux script, they need to start with a shebang:
#!/bin/sh
Welcome To SNBForums
