MoCA question...there's an amplified splitter that Comcast added to my cable entry box. It's "remotely" powered by an indoor power supply at my TV. The cable feed into the house is used as the path for both power for the amplified splitter and the path for cable TV into my house. This creates a challenge for me in terms of wiring in a MoCA adapter that I may have figured out. If I wire the MoCA adapter in as given in the mfr instructions, the cable-in from the amplified splitter to the MoCA adapter cable-in, and the cable-out of the MoCA adapter to the amplified splitter power supply, that breaks the path of the power for the amplifier and doesn't work.
My thought is to put in a splitter for the cable into the house from the amplified splitter. One output from this added splitter would go to the amplified splitter power supply, and the other output would go to the MoCA adapter cable-in. The splitter output that goes to the amplified splitter output would pass DC power, the splitter port that goes to the MoCA adapter would not pass power. I see 2-way splitters out there that have only one output port that passes DC power that seem to be meant for this sort of application.
So the power path for the amplified splitter would still be there, but the MoCA adapter wouldn't be getting the power meant for the amplified splitter. Does this sound like it would work? Does there have to be anything special about the splitter that I use for this? I've found a splitter that seems to fill the bill, and it goes up to above 2GHz. in bandwidth:
https://www.amazon.com/gp/product/B002UC2V8K/?tag=snbforums-20
Thanks!
Thanks!
