http://bgp.he.net/search?search[search]=netflix&commit=SearchSO i have merlin installed with selective routing for a vpn that works for netflix
I need to get the correct ip ranges for netflix for routing to work
can anyone help me get those ip ranges
Can you clarify what you are trying to accomplish? The way I understand from your post, it appears you have a VPN provider that works with NF. So why the need to get the IP ranges for NF? Sorry, I just want to help if I can. Do you want to use policy rules? e.g. only certain devices use VPN and others use native WAN?SO i have merlin installed with selective routing for a vpn that works for netflix
Thanks for clarifying. There are several ways to accomplish what you want to do, depending on your requirements.I want the vpn to only route traffic for netflix via it and leave everything else
Maybe this will help as well as another check.I was able to get hulu working with updated domain names
nslookup www.hulu.com
nslookup hulu.com
nslookup releasegeo.hulu.com no longer works it is now vortex.hulu.com
I will try doing the same with Netflix later today
netflix.com. 59 IN A 52.5.89.35
netflix.com. 59 IN A 52.45.81.31
netflix.com. 59 IN A 52.5.104.12
netflix.com. 59 IN A 52.45.226.110
netflix.com. 59 IN A 52.54.71.157
netflix.com. 59 IN A 52.54.76.119
netflix.com. 59 IN A 52.5.79.73
netflix.com. 59 IN A 52.54.254.24
www.netflix.com. 1724 IN CNAME www.geo.netflix.com.
www.geo.netflix.com. 1570 IN CNAME www.us-west-2.prodaa.netflix.com.
www.us-west-2.prodaa.netflix.com. 46 IN A 52.42.246.49
www.us-west-2.prodaa.netflix.com. 46 IN A 52.42.235.31
www.us-west-2.prodaa.netflix.com. 46 IN A 52.43.10.174
www.us-west-2.prodaa.netflix.com. 46 IN A 52.42.68.185
www.us-west-2.prodaa.netflix.com. 46 IN A 52.42.250.151
www.us-west-2.prodaa.netflix.com. 46 IN A 52.42.228.237
www.us-west-2.prodaa.netflix.com. 46 IN A 52.43.110.107
www.us-west-2.prodaa.netflix.com. 46 IN A 52.43.211.100
netflix.com. 899 IN SOA ns-81.awsdns-10.com. awsdns-hostmaster.amazon.com. 1 7200 900 1209600 1800
Like NF, Hulu also blocks VPNs. That is what may be going on. But it looks like it is working if you don't use routing. What is the error message you get? Some VPNs may be able to get around NF blocks but not Hulu.Thanks for the fast reply
i am facing a error with hulu it says to turn off unblocking service with routing however if i connect to vpn without routing it works perfect any help
Hmm, sounds like a symptom of a DNS leak when using routing. Go to ipleak.net to see. In your VPN Custom Configuration area, try to enter the ip address of your providers DNS servers as follows:It is not a problem with vpn but with routing
the vpn provider is able to bypass hulu when used without routing it is just when i use it with routing it says please turn off unblocker on hulu
You're welcome. Sorry I can't help any further. Hopefully, @Martineau will have time to help you out as this is one of his areas of expertise.Thanks for help still the same error
Welcome To SNBForums
