ca110475
newbie here, apologies for any silly question.
I just installed and configured today for my domestic network a new Asus AC87U, replacing a 6y old Netgear WNDR3700.
First thing i did was flashing latest stable Merlin 380.58, then set up all the network: everything works smoothly.
I just have a couple of questions and (maybe) a small problem.
1. Should i want to test the latest 380.59 BETA1, is a factory reset recommended or i can save a profile and safely load my settings from previous 380.58?
2. This is regarding channel bandwidth. I've read several different articles on the web and a few posts here on SNB but still unsure. I'm using just the 5Ghz radio. What channel bandwidth would you recommend? I live in a crowded place but from what i can sniff around all the neighbours are using 2.4Ghz APs. Would you set channel bandwidth to 80Mhz or 40 like i did? My clients are a mix of AC and N only capable devices. What i noticed is that when CB is 40Mhz, the Tx rate and Rx rate in Clients view seems to improve for some of them, compared to when i choose 80Mhz.
3. Last, the only issue i seem to have with the AC87U: ntp server is correctly set in Administration -> System -> Miscellaneous but for some reason the router seems unable to sync time and date. I've tried several different NTP servers. Router logs always show:
Aug 1 03:23:12 ntp: start NTP update
Aug 1 03:23:15 ntp: start NTP update
Aug 1 03:23:18 ntp: start NTP update
Aug 1 03:23:21 ntp: start NTP update
Aug 1 03:23:24 ntp: start NTP update
Aug 1 03:23:27 ntp: start NTP update
Aug 1 03:23:30 ntp: start NTP update
Aug 1 03:23:33 ntp: start NTP update
Aug 1 03:23:36 ntp: start NTP update
Aug 1 03:23:39 ntp: start NTP update
Aug 1 03:23:42 ntp: start NTP update
Aug 1 03:23:45 ntp: start NTP update
Aug 1 03:23:48 ntp: start NTP update
Aug 1 03:23:51 ntp: start NTP update
Aug 1 03:23:54 ntp: start NTP update
Aug 1 03:23:57 ntp: start NTP update
Aug 1 03:24:00 ntp: start NTP update
Aug 1 03:24:03 ntp: start NTP update
Aug 1 03:24:06 ntp: start NTP update
Aug 1 03:24:09 ntp: start NTP update
And this goes on and on indefinitely. Any clue / suggestion?
Thanks in advance
Thanks in advance
