Solved OpenVPN Server Issue
Wishmaster1965
I have been running this with no issue as a server up until I did a clean Factory reset after installing 388.4.
I setup 2 clients with passwords, setup Both for "Client will use VPN to access" and change to 2048 for RSA Encryption. In Advanced I change the IP to 10.10.10.0/C.
I export the VPN config file and load to my 2 Android devices using the Open VPN Client on each client.
As I understand this with "Client will use VPN to access" Both , will force my android device to use my home internet where I can leverage AdGaurd.
AdGuard DNS setting has my main DHCP Range and OpenVPN DHCP Range added to Allowed Clients
But the issue I am seeing is once connected I can access services at Home on my NAS, but I get no internet when using android browsers.
I have nothing configured in Advanced / Custom Configuration. I this OK ?
Router IP is 192.168.1.254
Log when I successfully connect
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, OU=Home/Office, CN=RT-AX88U, emailAddress=me@asusrouter.lan
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, OU=Home/Office, CN=client, emailAddress=me@asusrouter.lan
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 peer info: IV_VER=3.git::081bfebe:RelWithDebInfo
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 peer info: IV_PLAT=android
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 peer info: IV_NCP=2
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 peer info: IV_TCPNL=1
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 peer info: IV_PROTO=30
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 peer info: IV_CIPHERS=AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305:BF-CBC
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 peer info: IV_GUI_VER=net.openvpn.connect.android_3.3.4-9290
Sep 10 18:41:29 ovpn-server1[3993]: 9SOMEIP:36166 peer info: IV_SSO=webauth,openurl,crtext
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 peer info: IV_BS64DL=1
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=0
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 TLS: Username/Password authentication succeeded for username 'pixel'
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 TLS: tls_multi_process: initial untrusted session promoted to trusted
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA256
Sep 10 18:41:29 ovpn-server1[3993]: SOMEIP:36166 [client] Peer Connection Initiated with [AF_INET6]::ffff:92.40.194.3:36166 (via ::ffff:86.142.26.204%ppp0)
Sep 10 18:41:29 ovpn-server1[3993]: client/SOMEIP:36166 MULTI_sva: pool returned IPv4=10.10.10.2, IPv6=(Not enabled)
Sep 10 18:41:29 ovpn-server1[3993]: client/SOMEIP:36166 MULTI: Learn: 10.10.10.2 -> client/92.40.194.3:36166
Sep 10 18:41:29 ovpn-server1[3993]: client/SOMEIP:36166 MULTI: primary virtual IP for client/92.40.194.3:36166: 10.10.10.2
Sep 10 18:41:29 ovpn-server1[3993]: client/SOMEIP:36166 SENT CONTROL [client]: 'PUSH_REPLY,route 192.168.1.0 255.255.255.0 vpn_gateway 500,dhcp-option DOMAIN lan,dhcp-option DNS 192.168.1.254,redirect-gateway def1,route-gateway 10.10.10.1,topology subnet,ping 15,ping-restart 60,ifconfig 10.10.10.2 255.255.255.0,peer-id 0,cipher AES-256-GCM,key-derivation tls-ekm' (status=1)
Sep 10 18:41:29 ovpn-server1[3993]: client/SOMEIP:36166 PUSH: Received control message: 'PUSH_REQUEST'
Sep 10 18:41:30 ovpn-server1[3993]: client/SOMEIP:36166 Data Channel: cipher 'AES-256-GCM', peer-id: 0
Sep 10 18:41:30 ovpn-server1[3993]: client/SOMEIP:36166 Timers: ping 15, ping-restart 120
Sep 10 18:41:30 ovpn-server1[3993]: client/SOMEIP:36166 Protocol options: protocol-flags tls-ekm
I am at a loss where to check next, is it adguard or OpenVPN config I need to get this working ?
After you make changes to VPN server configuration - reboot your router. Try again Internet access from connected clients.
Did that multiple times
I don't have any Asus routers running at the moment, but from memory - have you checked something like Advertise DNS to Clients in the OpenVPN Server settings? Also you may want to remove this copy/paste of your log. It contains your WAN IP and port number. No need to advertise it online.
I had enabled Advertise DNS to Clients and it had no difference, and that's not my WAN address its my phones IP using Data.
Just tested it again after exporting config and importing to my phone, Looks like that advertise DNS to Clients was not enabled in the old config.
Thanks for the assist @Tech9
