Private Wi-Fi Address
jrmwvu04
Just a heads up for everyone..
iOS 14, at least in beta, has a feature they call Private Wi-Fi Address that is enabled by default. This means that each time the device connects to your network, it will do so with a unique MAC address. The effect of which is that it will break static addresses and/or things like QoS rules that are instituted by MAC address. It can be disabled, but you must manually do so for each network.
Is this setting for each known SSID? I mean, can you set it off for your home LAN SSIDs but go "incognito" when connected on public wifi?
Some Android variations have been doing this for a while as default. It can be disabled.
OP cleared states it can be disabled per network.
The screenshot is of the settings for a known SSID.
Same on latest Android, and on by default, which I think it is good in matters if security, but a pia in terms of easy-to-use
This is correct. It is on by default and cannot be disabled globally as far as I can tell. It must be disabled manually per SSID.
Just checked my Samsung Note 10 (latest Android) and see it was set to randomize. I have separate 2.4 and 5 GHz SSIDs and oddly, turning it Off on the 5GHz SSID seemed to turn it Off on the 2.4 also. Note: it seems that you need to be currently connected to the SSID in order to see this setting.
So that explains why my DHCP wasn't assigining the static IP. I need to fix this also on my wife's phone.
How does having a random MAC improve security? And how does the process ensures there are no duplicates, since the address allocation won't be controlled by the IEEE?
I think they are confusing security with privacy.
Re duplicates, there are 2 to the 46 unique "locally-administered" MAC addresses (there is a bit in the MAC which says if it’s a globally assigned address with a registered OUI or a locally assigned random one). This gives 70,368,744,177,664 possibilities, so I think they are working on the basis that in the same Layer 2 segment the chances are very slim, plus all modern OS’s handle MAC duplicate by reassigning a new locally administered one if detected in this case (or telling the user if they assigned a manual one).
