Hi, i.m trying connect with asus merlin to server openvpn in tap mode.
When use client in windows work fine.
But in asus connect, but dont ip: Connected (Local: 0.0.0.0 - Public: )
My server.conf:
port 45678
proto udp
dev tap0
mode server
tls-server
ca /etc/openvpn/easy-rsa/keys/ca.crt
cert /etc/openvpn/easy-rsa/keys/server.crt
key /etc/openvpn/easy-rsa/keys/server.key
dh /etc/openvpn/easy-rsa/keys/dh2048.pem
remote-cert-tls client
server-bridge 192.168.1.100 255.255.255.0 192.168.1.240 192.168.1.250
push "redirect-gateway def1"
push "dhcp-option DNS 8.8.4.4"
client-to-client
keepalive 10 120
tls-auth /etc/openvpn/easy-rsa/keys/ta.key 0
cipher AES-256-GCM
compress lz4-v2
push "compress lz4-v2"
persist-key
persist-tun
status /var/log/openvpn-status.log
log-append /var/log/openvpn.log
My client conf:
client
dev tap0
proto udp
remote xxxx.dyndns.org 45678
tls-client
persist-key
persist-tun
ca ca.crt
cert xxxxx.crt
key xxxxx.key
remote-cert-tls server
tls-auth ta.key 1
cipher AES-256-GCM
compress lz4-v2
verb 3
My interfaces:
br0 Link encap:Ethernet HWaddr 00:1e:06:10:1c:c6
inet addr:192.168.1.100 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::21e:6ff:fe10:1cc6/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:19 errors:0 dropped:0 overruns:0 frame:0
TX packets:20 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1910 (1.8 KiB) TX bytes:2852 (2.7 KiB)
eth0 Link encap:Ethernet HWaddr 00:1e:06:10:1c:c6
UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1
RX packets:276 errors:0 dropped:0 overruns:0 frame:0
TX packets:248 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:29344 (28.6 KiB) TX bytes:38899 (37.9 KiB)
Interrupt:40
tap0 Link encap:Ethernet HWaddr 8e:22:70:28:2d:d8
UP BROADCAST PROMISC MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
My server.conf:
port 45678
proto udp
dev tap0
mode server
tls-server
client-to-client
keepalive 10 120
cipher AES-256-GCM
compress lz4-v2
persist-key
persist-tun
My client conf:
client
dev tap0
proto udp
tls-client
persist-key
persist-tun
ca ca.crt
cert xxxxx.crt
key xxxxx.key
tls-auth ta.key 1
cipher AES-256-GCM
compress lz4-v2
verb 3
My interfaces:
Interrupt:40
