Problem with VPN Director
L&LD
Part of the Furniture
Show screenshots.
You're doing something wrong.
I would like to report an issue with the network planning of the Virtual Private Network (VPN Director) when a rule was added to individual IP address 192.168.77.30/24 to connect to the VPN network. This has resulted in redirecting the entire subnet's routing 92.168.77.0/24 to connect to the VPN.
can some one help
Asuswrt-Merlin
Firmware:3004.388.6
Please do not cross-post the same topic all over the forums.
Makes it hard to have a concise conversation when there are multiple posts/replies.
can some one help
Asuswrt-Merlin
Firmware:3004.388.6
That is because you are specifying the entire subnet, 192.168.77.30/24. The /24 part means the subnet mask is 255.255.255.0. If you want to only specify one address use just the IP address, 192.168.77.30.
i like to report NAT Problem with VPN Director when i add rule to Nat Single IP 192.168.77.30/24 to vpn concoction the whole subnet 92.168.77.0/24 redirected to vpn connection
How is this a problem?
https://en.m.wikipedia.org/wiki/Classless_Inter-Domain_Routing
Using cidr blocks as used by routing, by /24 you imply that 24 most significant bits, basically nullifies your .30 as it will be masked away.
If you want to specify any single ip, use /32 or usually leave ip without cidr notation.
