Guys,
Need some serious advise on this. I'm currently on the hunt for a single-bay NAS device for home lab stuff. I did some extensive research and finally came up with the following two choices. I need your help in deciding between the following two.
1. Qnap TS-112P
2. Synology DS114
Barring the difference in processor speed (Qnap has an edge) the above two products are almost equal. Of course the Synology is a bit pricier - around $50 more than the Qnap
I'll be creating a large number of iSCSI volumes which will be accessed from inside Virtual Machines, so iSCSI performance should alteast be decent. I'd also be doing a lot of testing on NFS.
Pls advise which one will be best NAS device for my requirement.
1. Qnap TS-112P
2. Synology DS114
