QoS Help - Activate fq_codel via script
JRes
I just want to check the best possible way to switch to fq_codel QoS discipline via script without installing FlexQOS.
I am currently using Asus Adaptive QoS and just want to switch the discpline to fq_codel, retaining DB rules.
Tried searching the forum but most post I see recommending installing FlexQoS or FreshJR.
Thanks.
It's not something that you can "activate", it requires a mechanism that will read the generated ip rules, and rewrite them to use fq_codel. Unless you wish to reinvent the wheel, FlexQOS remains the simplest way to do it.
