Random disconnection of multiple devices
cyu6722
I have a ax88u and ax58u node on aimesh. Both on 386.3_2. I have around 40~ devices connected at all times ranging from lightbulbs to pcs. On occasion some of my devices would lose usually the 5G network and then can't reconnect. I would see the device number all of a sudden drop to 25 devices from 40, a big dip. They would say unable to obtain IP address and other sorts of issues. This just happened with my S8 but i was able to reconnect after jumping to 2.4 Ghz and then back to 5Ghz. I pasted the system logs from that time frame. Not sure if anything stands out or other logs are needed.
From my experience it seems my ax88u has a habit of dropping all 5ghz devices while keeping 2.4ghz devices on it but i haven't see the same issue on the ax58u.
Aug 30 21:16:23 RT-AX88U-A318 hostapd: eth7: STA 56:af:89:a9:6f:50 IEEE 802.11: associated
Aug 30 21:16:23 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Aug 30 21:16:23 RT-AX88U-A318 hostapd: eth7: STA 56:af:89:a9:6f:50 RADIUS: starting accounting session FA5584E4B1BB0DEA
Aug 30 21:16:23 RT-AX88U-A318 hostapd: eth7: STA 56:af:89:a9:6f:50 WPA: pairwise key handshake completed (RSN)
Aug 30 21:16:27 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPREQUEST(br0) 192.168.50.101 56:af:89:a9:6f:50
Aug 30 21:16:27 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPACK(br0) 192.168.50.101 56:af:89:a9:6f:50 iPhone
Aug 30 21:18:00 RT-AX88U-A318 hostapd: eth7: STA 56:af:89:a9:6f:50 IEEE 802.11: disassociated
Aug 30 21:20:22 RT-AX88U-A318 hostapd: eth6: STA ac:ae:19:c4:c1:5f IEEE 802.11: disassociated
Aug 30 21:20:23 RT-AX88U-A318 hostapd: eth6: STA ac:ae:19:c4:c1:5f IEEE 802.11: associated
Aug 30 21:20:23 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Aug 30 21:20:23 RT-AX88U-A318 hostapd: eth6: STA ac:ae:19:c4:c1:5f RADIUS: starting accounting session B8D1E06EDC327070
Aug 30 21:20:23 RT-AX88U-A318 hostapd: eth6: STA ac:ae:19:c4:c1:5f WPA: pairwise key handshake completed (RSN)
Aug 30 21:20:24 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPREQUEST(br0) 192.168.50.140 ac:ae:19:c4:c1:5f
Aug 30 21:20:24 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPACK(br0) 192.168.50.140 ac:ae:19:c4:c1:5f RokuExpress
Aug 30 21:24:33 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPREQUEST(br0) 192.168.50.222 14:c1:4e:9c:37:79
Aug 30 21:24:33 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPACK(br0) 192.168.50.222 14:c1:4e:9c:37:79 Nest-Thermostat-3779
Aug 30 21:24:34 kernel: br0: received packet on eth7 with own address as source address
Aug 30 21:24:34 RT-AX88U-A318 hostapd: eth7: STA a0:cc:2b:88:df:26 IEEE 802.11: associated
Aug 30 21:24:34 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Aug 30 21:24:36 RT-AX88U-A318 hostapd: eth7: STA a0:cc:2b:88:df:26 RADIUS: starting accounting session 2333D50EBF4286ED
Aug 30 21:24:36 RT-AX88U-A318 hostapd: eth7: STA a0:cc:2b:88:df:26 WPA: pairwise key handshake completed (RSN)
Aug 30 21:25:14 RT-AX88U-A318 hostapd: eth7: STA a0:cc:2b:88:df:26 IEEE 802.11: associated
Aug 30 21:25:14 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Aug 30 21:25:16 RT-AX88U-A318 hostapd: eth7: STA a0:cc:2b:88:df:26 RADIUS: starting accounting session 2333D50EBF4286ED
Aug 30 21:25:16 RT-AX88U-A318 hostapd: eth7: STA a0:cc:2b:88:df:26 WPA: pairwise key handshake completed (RSN)
Aug 30 21:25:38 RT-AX88U-A318 hostapd: eth7: STA a0:cc:2b:88:df:26 IEEE 802.11: disassociated
Aug 30 21:25:56 RT-AX88U-A318 hostapd: eth6: STA a0:cc:2b:88:df:26 IEEE 802.11: associated
Aug 30 21:25:56 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Aug 30 21:25:56 RT-AX88U-A318 hostapd: eth6: STA a0:cc:2b:88:df:26 RADIUS: starting accounting session 927AAA42C4A80565
Aug 30 21:25:56 RT-AX88U-A318 hostapd: eth6: STA a0:cc:2b:88:df:26 WPA: pairwise key handshake completed (RSN)
Aug 30 21:25:56 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPREQUEST(br0) 192.168.50.209 a0:cc:2b:88:df:26
Aug 30 21:25:56 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPACK(br0) 192.168.50.209 a0:cc:2b:88:df:26 Galaxy-S8
Aug 30 21:27:56 kernel: Init chrdev /dev/idp with major 190
Aug 30 21:27:56 kernel: tdts: tcp_conn_max = 8000
Aug 30 21:27:56 kernel: tdts: tcp_conn_timeout = 300 sec
Aug 30 21:27:58 kernel: SHN Release Version: 2.0.1 8279cad
Aug 30 21:27:58 kernel: UDB Core Version: 0.2.20
Aug 30 21:27:58 kernel: Init chrdev /dev/idpfw with major 191
Aug 30 21:27:58 kernel: IDPfw: flush fc
Aug 30 21:27:58 kernel: IDPfw: IDPfw is ready
Aug 30 21:27:58 kernel: sizeof forward pkt param = 280
Aug 30 21:27:58 RT-AX88U-A318 BWDPI: fun bitmap = 3
Aug 30 21:28:04 RT-AX88U-A318 hostapd: eth6: STA a0:cc:2b:88:df:26 IEEE 802.11: disassociated
Aug 30 21:28:05 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPREQUEST(br0) 192.168.50.209 a0:cc:2b:88:df:26
Aug 30 21:28:05 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPACK(br0) 192.168.50.209 a0:cc:2b:88:df:26 Galaxy-S8
Aug 30 21:28:09 RT-AX88U-A318 BWDPI: force to flush flowcache entries
Aug 30 21:28:09 kernel: IDPfw: Exit IDPfw
Aug 30 21:28:09 kernel: mod epilog takes 0 jiffies
Aug 30 21:28:09 kernel: Exit chrdev /dev/idpfw with major 191
Aug 30 21:28:09 kernel: Exit chrdev /dev/idp with major 190
Aug 30 21:28:09 RT-AX88U-A318 BWDPI: rollback fc
Aug 30 21:28:09 RT-AX88U-A318 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Aug 30 21:28:26 kernel: DROP IN=eth0 OUT= MAC=24:4b:fe:d1:a3:18:cc:ab:2c:17:62:c1:08:00 SRC=167.99.204.151 DST=ip LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=54321 PROTO=TCP SPT=57769 DPT=1085 SEQ=1107125624 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Aug 30 21:28:27 kernel: DROP IN=eth0 OUT= MAC=24:4b:fe:d1:a3:18:cc:ab:2c:17:62:c1:08:00 SRC=34.235.4.153 DST=ip LEN=48 TOS=0x0C PREC=0x60 TTL=49 ID=28945 DF PROTO=UDP SPT=32099 DPT=18404 LEN=28 MARK=0x8000000
Aug 30 21:28:27 kernel: DROP IN=eth0 OUT= MAC=24:4b:fe:d1:a3:18:cc:ab:2c:17:62:c1:08:00 SRC=18.223.127.200 DST=ip LEN=48 TOS=0x0C PREC=0x60 TTL=32 ID=29426 DF PROTO=UDP SPT=32099 DPT=18404 LEN=28 MARK=0x8000000
Aug 30 21:28:27 kernel: DROP IN=eth0 OUT= MAC=24:4b:fe:d1:a3:18:cc:ab:2c:17:62:c1:08:00 SRC=54.153.101.7 DST=ip LEN=48 TOS=0x0C PREC=0x60 TTL=44 ID=53420 DF PROTO=UDP SPT=32099 DPT=18404 LEN=28 MARK=0x8000000
Aug 30 21:28:28 kernel: DROP IN=eth0 OUT= MAC=24:4b:fe:d1:a3:18:cc:ab:2c:17:62:c1:08:00 SRC=74.207.234.47 DST=ip LEN=44 TOS=0x00 PREC=0x00 TTL=53 ID=29233 DF PROTO=UDP SPT=51488 DPT=44025 LEN=24 MARK=0x8000000
Aug 30 21:28:28 kernel: DROP IN=eth0 OUT= MAC=24:4b:fe:d1:a3:18:cc:ab:2c:17:62:c1:08:00 SRC=45.56.113.17 DST=ip LEN=44 TOS=0x00 PREC=0x00 TTL=53 ID=28663 DF PROTO=UDP SPT=46480 DPT=44025 LEN=24 MARK=0x8000000
Aug 30 21:28:31 kernel: DROP IN=eth0 OUT= MAC=24:4b:fe:d1:a3:18:cc:ab:2c:17:62:c1:08:00 SRC=45.56.113.17 DST=ip LEN=44 TOS=0x00 PREC=0x00 TTL=53 ID=29068 DF PROTO=UDP SPT=46480 DPT=44208 LEN=24 MARK=0x8000000
Aug 30 21:28:31 kernel: DROP IN=eth0 OUT= MAC=24:4b:fe:d1:a3:18:cc:ab:2c:17:62:c1:08:00 SRC=74.207.234.47 DST=ip LEN=44 TOS=0x00 PREC=0x00 TTL=53 ID=29666 DF PROTO=UDP SPT=51488 DPT=44208 LEN=24 MARK=0x8000000
Aug 30 21:28:37 RT-AX88U-A318 YazFi: Firewall restarted - sleeping 30s before running YazFi
Aug 30 21:29:07 RT-AX88U-A318 YazFi: YazFi v4.3.4 starting up
Aug 30 21:29:10 RT-AX88U-A318 YazFi: wl1.2 (SSID: YuCrib_Guest) - sending all interface internet traffic over WAN interface
Aug 30 21:29:12 RT-AX88U-A318 YazFi: Forcing YazFi Guest WiFi clients to reauthenticate
Aug 30 21:29:12 RT-AX88U-A318 hostapd: eth7: STA bc:14:85:66:0d:f1 IEEE 802.11: disassociated
Aug 30 21:29:12 RT-AX88U-A318 hostapd: eth7: STA 00:00:00:00:00:00 IEEE 802.11: disassociated
Aug 30 21:29:22 RT-AX88U-A318 networkmap: Error unlocking 7: 9 Bad file descriptor
Aug 30 21:29:22 RT-AX88U-A318 networkmap: Error unlocking 0: 9 Bad file descriptor
Aug 30 21:29:27 RT-AX88U-A318 YazFi: YazFi v4.3.4 completed successfully
Aug 30 21:29:31 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Aug 30 21:29:31 RT-AX88U-A318 hostapd: eth7: STA bc:14:85:66:0d:f1 IEEE 802.11: associated
Aug 30 21:29:31 RT-AX88U-A318 hostapd: eth7: STA bc:14:85:66:0d:f1 RADIUS: starting accounting session 379A242BD7DEBBE2
Aug 30 21:29:31 RT-AX88U-A318 hostapd: eth7: STA bc:14:85:66:0d:f1 WPA: pairwise key handshake completed (RSN)
Aug 30 21:29:31 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPREQUEST(br0) 192.168.50.36 bc:14:85:66:0d:f1
Aug 30 21:29:31 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPACK(br0) 192.168.50.36 bc:14:85:66:0d:f1
Aug 30 21:29:31 RT-AX88U-A318 dnsmasq-script[20998]: json_object_from_file: error opening file /jffs/nmp_vc_json.js: No such file or directory
Aug 30 21:31:11 RT-AX88U-A318 hostapd: eth7: STA bc:14:85:66:0d:f1 IEEE 802.11: disassociated
Aug 30 21:31:14 kernel: br0: received packet on eth7 with own address as source address
Aug 30 21:31:14 RT-AX88U-A318 hostapd: eth7: STA a0:cc:2b:88:df:26 IEEE 802.11: associated
Aug 30 21:31:14 RT-AX88U-A318 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Aug 30 21:31:19 RT-AX88U-A318 hostapd: eth7: STA a0:cc:2b:88:df:26 IEEE 802.11: disassociated
Aug 30 21:31:24 RT-AX88U-A318 hostapd: eth6: STA ac:ae:19:c4:c1:5f IEEE 802.11: disassociated
Aug 30 21:31:29 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPDISCOVER(br0) a0:cc:2b:88:df:26
Aug 30 21:31:29 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPOFFER(br0) 192.168.50.209 a0:cc:2b:88:df:26
Aug 30 21:31:29 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPREQUEST(br0) 192.168.50.209 a0:cc:2b:88:df:26
Aug 30 21:31:29 RT-AX88U-A318 dnsmasq-dhcp[20998]: DHCPACK(br0) 192.168.50.209 a0:cc:2b:88:df:26 Galaxy-S8
I am actually having same/similar issue. AX88U running latest Merlin (386.8 at time of writing) and two AiMesh routers running stock (latest) FW (one AC68U and one AX92U)
A couple of similarities:
  1. I do have many devices, 84 currently connected at time of writing, many smart relays (mainly Shellys)
  2. The device I am noticing this on first is my Phone, a S21 i.e. also Samsung on 5GHz (and WiFi 6). I do however think that this is an issue that is not related to "a Samsung phone" as my daughters Acer laptop also got disconnected once, at the same time as my phone this weekend.
  3. I am also experiencing "json_object_from_file: error opening file /jffs/nmp_vc_json.js: No such file or directory", and a lot of them. I'd say several per minute at times. Haven't figured out what they mean yet..
  4. I also have experienced firewall (and QoS) restarts like you did in your example log: "custom_script: Running /jffs/scripts/firewall-start (args: eth0)"
    1. Also uninstalled YazDHCP
  5. I have removed DHCP work load from the AX88U, just to remove as much as possible to exclude possible error sources. (On a RPi running PiHole now)
  6. I tried disabling custom scripts. Didn't help so I re-enabled again to be able to log to external log server.
  7. Disabled Roaming Assistant on both 2.4 and 5 GHz (as some people have experienced issues and some stating RA should not be needed when using modern AiMesh)
  8. Have setup a Graylog Server just to be able to collect and work with these logs from the router :cool:. So upside is I now have a very competent log infrastructure in place...
Nothing have helped so far. As you can see, very much work in progress when it comes to troubleshooting, but I'd be very interested in knowing if you found a solution that might have helped you.
