Remote Log Server and dnsmasq-dhcp in router log
-AndyH-
Hi
Got a couple of questions:
1) Remote Log Server - How does this work? Which software do I need to log things from my router (I have a dedicated server running WHS 2011)?
2) Router System Log - Since upgrading to x.270, I have been getting hundreds of dnsmasq-dhcp/DHCPINFORM(br0)/DHCPREQUEST(br0) messages in the system log. Is there anyway I can disable those specific messages (they are spamming my log!)?
Hi
1) You need ro run a syslog daemon on the target computer.
2) Not with the stock firmware, no.
Thanks for the responses.
Any clues on how to set up Wall Watcher with the N66U? It doesn't seem to be able to connect/pick up data from the router.
For me, it automatically received the messages, but was not able to parse them correctly, and basically I ended up with just a huge single field with all the data in it.
