spacemanspiff
Yeah, I'm a long time dd-wrt guy, but the vpn implementation on dd-wrt is full of headache and hassles and their was a substantial performance hit on WAN throughput with dd-wrt + ac3200. I was seeing max throughput in the low 800mbps range using dd-wrt....switching to Merlin and throughput immediate went up to the 960mbps range. Maybe that's gotten better over time, but Merlin meets my power user needs and the openvpn configuration is far simpler. If I can sustain even 100mbps VPN performance over Merlin with an RT-AX86U then that is plenty for my needs when I'm travelling and want to use a secure VPN through my own fibre connect.yes it is hard if you have very good router like AC3200 and the only reason you need to replaced it because is not support by RMerlin any more. In any other case router you have would be sufficient for next 10 years . This is the reason that I am moving between different software like DD-WRT-tomato- lately RMerlin but in few months I plan to move to UBIQUITI ER-12 router.
I am not sure what are your experiences/ needs with VPN but I tested RT-AX88U at my friend loc and VPN max speed was below 300Mbits, when I tested ER-12 it went 1Gbit, cakeQOS at this Asus router was about 250Mbit and at ER-12 was a bit above 500Mbit.
If your AC3200 was OK for you I would not spend a lot money at new router what think more like replacing it every 5y and go with https://wikidevi.wi-cat.ru/ASUS_RT-AX56U
if you want to have 1Gbit on VPN sry but RT-AX88U will not be even at 1/3 of it.
if you are typical user AX56U will be OK for 1GBit - if you advanced user (QoS, VPN, etc) for 300Mbit above you will need to look for something different than ASUS/Netgear etc.
