RT-AC66U_B1 OpenVPN help
David Gursky
I have a pair of RT-AC66U_B1 routers with OpenVPN set up between them -- a client (Maryland, 192.168.58.XXX) and server (Virginia, 192.168.60.xxx). Virginia is showing that Maryland has successfully connected to it. Furthermore, I can access the Web UI for LAN side of Virginia (i.e. https://192.168.60.1:8443) from the LAN side of Maryland., so I am certain that the VPN is up.
What I CAN'T do (and what I want to do) is access the SMB resources on Virginia from Maryland (i.e. \\192.168.60.108\C$) I have disabled the firewall on both sides as a test, but to no avail.
What am I missing here? [FWIW, the error I get on the Maryland side when using SMB to access Virginia is 80004005
