This is my first question here om this forum. Hoop it's not a noob one but I really can use some help here.
I have a Asus RT-AC68U with Asuswrt-merlin v380.59 running perfect and without problems. Connected to the router I have some cam's and mineOS server running. All is running without problems and can be accessed from the internet. Also de Routers webGUI can I connect from the internet.
Now I want to run the OpenVPN client on the router so that my whole network is behind the VPN connection. I have a VPN subscription at AirVPN and setting up the VPN connection is no problem at all.
So far so good.
Connecting to the server and webGUI on the local(internal) side is no problem but now I want to connect to de routers WebGUI or MineOS server of webcams from the internet side. I know my new VPN IP or DDNS from AirVPN. I can even do port forwarding on the AirVPN side. But whatever I try. I'm unable to reach the server and/or router WebUI.
I have searched a lot but unable to find any answer jet.
Is it what I want possible?
If yes, how is the setup then on the router side?
Thanks !!
So far so good.
Thanks !!
