This router is having an issue with rebooting. I will get great connection then all of the sudden it will reset? here is the log file.
Dec 31 16:00:07 syslogd started: BusyBox v1.17.4
Dec 31 16:00:07 syslog: module ledtrig-usbdev not found in modules.dep
Dec 31 16:00:07 syslog: module leds-usb not found in modules.dep
Dec 31 16:00:07 kernel: klogd started: BusyBox v1.17.4 (2015-01-10 18:59:17 CST)
Dec 31 16:00:07 kernel: start_kernel
Dec 31 16:00:07 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.3) #1 Sat Jan 10 19:02:22 CST 2015
Dec 31 16:00:07 kernel: CPU revision is: 00019749
Dec 31 16:00:07 kernel: Determined physical RAM map:
Dec 31 16:00:07 kernel: memory: 07fff000 @ 00000000 (usable)
Dec 31 16:00:07 kernel: memory: 08000000 @ 87fff000 (usable)
Dec 31 16:00:07 kernel: Built 1 zonelists. Total pages: 585216
Dec 31 16:00:07 kernel: Kernel command line: root=/dev/mtdblock2 noinitrd console=ttyS0,115200
Dec 31 16:00:07 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Dec 31 16:00:07 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Dec 31 16:00:07 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Dec 31 16:00:07 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Dec 31 16:00:07 kernel: Using 300.000 MHz high precision timer.
Dec 31 16:00:07 kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Dec 31 16:00:07 kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 31 16:00:07 kernel: Mount-cache hash table entries: 512
Dec 31 16:00:07 kernel: PCI: Initializing host
Dec 31 16:00:07 kernel: PCI: Reset RC
Dec 31 16:00:07 kernel: PCI: Fixing up bus 0
Dec 31 16:00:07 kernel: PCI/PCIe coreunit 0 is set to bus 1.
Dec 31 16:00:07 kernel: PCI: Fixing up bridge
Dec 31 16:00:07 kernel: PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
Dec 31 16:00:07 kernel: PCI: Fixing up bus 1
Dec 31 16:00:07 kernel: PCI/PCIe coreunit 1 is set to bus 2.
Dec 31 16:00:07 kernel: PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
Dec 31 16:00:07 kernel: PCI: Fixing up bus 2
Dec 31 16:00:07 kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Dec 31 16:00:07 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Dec 31 16:00:07 kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Dec 31 16:00:07 kernel: highmem bounce pool size: 64 pages
Dec 31 16:00:08 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Dec 31 16:00:08 kernel: Physically mapped flash: CFI does not contain boot bank location. Assuming top.
Dec 31 16:00:08 kernel: number of CFI chips: 1
Dec 31 16:00:08 kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Dec 31 16:00:08 kernel: Flash device: 0x2000000 at 0x1c000000
Dec 31 16:00:08 kernel: Creating 5 MTD partitions on "Physically mapped flash":
Dec 31 16:00:08 kernel: 0x00000000-0x00040000 : "pmon"
Dec 31 16:00:08 kernel: 0x00040000-0x01fe0000 : "linux"
Dec 31 16:00:08 kernel: 0x0016e474-0x01980000 : "rootfs"
Dec 31 16:00:08 kernel: 0x01fe0000-0x02000000 : "nvram"
Dec 31 16:00:08 kernel: 0x01ee0000-0x01fe0000 : "jffs2"
Dec 31 16:00:08 kernel: Found an serial flash with 0 0KB blocks; total size 0MB
Dec 31 16:00:08 kernel: sflash: found no supported devices
Dec 31 16:00:08 kernel: dev_nvram_init: _nvram_init
Dec 31 16:00:08 kernel: u32 classifier
Dec 31 16:00:08 kernel: OLD policer on
Dec 31 16:00:08 kernel: Netfilter messages via NETLINK v0.30.
Dec 31 16:00:08 kernel: nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
Dec 31 16:00:08 kernel: ipt_time loading
Dec 31 16:00:08 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 16:00:08 kernel: net/ipv4/netfilter/tomato_ct.c [Jan 10 2015 19:01:45]
Dec 31 16:00:08 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 16:00:08 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Dec 31 16:00:08 kernel: Warning: unable to open an initial console.
Dec 31 16:00:08 kernel: Algorithmics/MIPS FPU Emulator v1.5
Dec 31 16:00:08 kernel: ctf: module license 'Proprietary' taints kernel.
Dec 31 16:00:08 kernel: et_module_init: passivemode set to 0x0
Dec 31 16:00:08 kernel: et_module_init: et_txq_thresh set to 0x400
Dec 31 16:00:08 kernel: bcm_robo_enable_switch: EEE is disabled
Dec 31 16:00:08 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.163.2002 (r382208)
Dec 31 16:00:08 kernel: wl_module_init: passivemode set to 0x0
Dec 31 16:00:08 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Dec 31 16:00:08 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Dec 31 16:00:08 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Dec 31 16:00:08 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Dec 31 16:00:08 kernel: SCSI subsystem initialized
Dec 31 16:00:08 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c027d000
Dec 31 16:00:08 kernel: NTFS (with native replay) support included
Dec 31 16:00:08 kernel: optimized: speed
Dec 31 16:00:08 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Dec 31 16:00:10 stop_nat_rules: apply the redirect_rules!
Dec 31 16:00:10 WAN Connection: ISP's DHCP did not function properly.
Dec 31 16:00:11 kernel: scsi 0:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
Dec 31 16:00:11 kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
Dec 31 16:00:11 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Dec 31 16:00:14 dnsmasq[368]: warning: interface ppp1* does not currently exist
Dec 31 16:00:14 RT-N66U: start httpd
Dec 31 16:00:14 syslog: Generating SSL certificate...
Dec 31 16:00:15 disk monitor: be idle
Dec 31 16:00:15 miniupnpd[395]: HTTP listening on port 45068
Dec 31 16:00:15 miniupnpd[395]: Listening for NAT-PMP traffic on port 5351
Dec 31 16:00:16 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Dec 31 16:00:17 kernel: nf_conntrack_rtsp v0.6.21 loading
Dec 31 16:00:17 kernel: nf_nat_rtsp v0.6.21 loading
Dec 31 16:00:17 rc_service: udhcpc 413:notify_rc stop_upnp
Dec 31 16:00:17 miniupnpd[395]: received signal 15, good-bye
Dec 31 16:00:18 rc_service: udhcpc 413:notify_rc start_upnp
Dec 31 16:00:18 ddns update: ez-ipupdate: starting...
Dec 31 16:00:18 miniupnpd[469]: HTTP listening on port 58164
Dec 31 16:00:18 miniupnpd[469]: Listening for NAT-PMP traffic on port 5351
Dec 31 16:00:18 ddns update: connected to ns1.asuscomm.com (103.10.4.108) on port 80.
Dec 31 16:00:18 ddns update: Asus update entry:: return: HTTP/1.1 200 OK^M Date: Wed, 25 Feb 2015 16:22:48 GMT^M Server: Apache/2.4.9 (Unix) PHP/5.5.14 OpenSSL/1.0.1h^M X-Powered-By: PHP/5.5.14^M Content-Length: 0^M Connection: close^M Content-Type: text/html^M ^M
Dec 31 16:00:18 ddns update: retval= 0, ddns_return_code (,200)
Dec 31 16:00:18 ddns update: asusddns_update: 0
Dec 31 16:00:18 ddns: ddns update ok
Dec 31 16:00:19 WAN Connection: WAN was restored.
Dec 31 16:00:22 ntp: start NTP update
Feb 25 08:22:51 rc_service: ntp 472:notify_rc restart_upnp
Feb 25 08:22:51 rc_service: ntp 472:notify_rc restart_diskmon
Feb 25 08:22:51 rc_service: waitting "restart_upnp" via ntp ...
Feb 25 08:22:51 miniupnpd[469]: received signal 15, good-bye
Feb 25 08:22:51 disk monitor: be idle
Feb 25 08:22:51 miniupnpd[480]: HTTP listening on port 40377
Feb 25 08:22:51 miniupnpd[480]: Listening for NAT-PMP traffic on port 5351
Feb 25 08:22:52 dhcp client: bound 98.175.206.24 via 98.175.206.1 during 86400 seconds.
Feb 25 08:23:31 crond[371]: time disparity of 2184023 minutes detected
Feb 25 08:57:11 rc_service: httpd 369:notify_rc restart_wireless
Feb 25 08:57:20 kernel: wl_module_init: passivemode set to 0x0
Feb 25 08:57:20 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Feb 25 08:57:20 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Feb 25 09:31:33 syslogd started: BusyBox v1.17.4
Feb 25 09:31:33 RT-N66U: start httpd
Feb 25 09:31:33 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Feb 25 09:31:33 kernel: klogd started: BusyBox v1.17.4 (2015-01-10 18:59:17 CST)
Feb 25 09:59:57 ntp: start NTP update
