Greetings,
I've just recently purchased a RV042, thanks in large part to the great reviews on this site. I have Comcast Business Class internet with the requisite SMC 8014(?) modem/router combo, and with a dynamic IP address. I've been reading a lot of forum threads across various forums, but they all tend to be geared more towards having a static IP, which I'd rather not pay for (and I don't really think is warranted for my needs).
Here are some of the kinds of things I'm seeing people suggest:
-use port 1 on the SMC;
-set secondary router (ie, the RV042, in my case) to be a DMZ host;
-turn off DHCP in the SMC (some say this isn't necessary).
I've experimented some with the above (though not the first one, because I hadn't come across that before I left the office), but haven't had any luck yet. I'm wanting to get things set up so that all of my LAN computers (which consists of a few computers and a few NAS's) are hooked up to the RV042 so that I can then VPN in and access those local LAN resources remotely. As part of this I think I need to be able to get DynDNS working such that it is able to automatically update itself within the RV042. That is one of the things that didn't seem to be working.
I have a rough idea of how things might be able to work conceptually, but I'm having trouble getting all the details straight. Here is what I have tried thus far and/or what I'm thinking thus far:
-I assigned an internal IP to the RV042 (from inside it's interface--I think the setting was "Device IP Address") so that it would stay consistent; the SMC is something like 10.1.10.1, so I assigned the RV042 to be 10.1.10.2.
-Pointing the RV042 to the SMC as its gateway still resulted in the RV042 being assigned a different address (something like 10.1.10.194) by the SMC (I think maybe this was the LAN IP in the RV info? I can't remember and I'm not in front of it right now). I could access the admin for the RV from a computer plugged into the RV via the 10.1.10.2 address.
-I wasn't sure whether I should put 10.1.10.2 in the DMZ field in the SMC or the .194 address. I thought that the first one should be correct, but I tried both and neither seemed to have any effect.
I'm going to have to go through all this more thoroughly when I have more time (which probably won't be until this weekend). One thing I wonder a little is if rebooting either/both devices after applying some of these settings would make a difference or not.
Another weird thing I noticed which could be affecting things is that the password field for entering my DynDNS account info seemed to be a lot shorter than what my password actually was. I'm not 100% certain, but that seems like quite a bug if in fact I'm going to have to shorten my password significantly in order for it to be used in the RV settings.
Thanks in advance for any input and help anyone can offer!
