Save setting to nvram
doubleroll
How can I save a particular setting to nvram so after a reboot I do not have to make the same changes?
example: ROBOCFG PORT 0 JUMBO ON
Not a big deal but it would be nice not to have to do this every time. Thx!
it would be easier to simply add that line to /jffs/scripts/services-start
or your original idea
saving a value would mean
saving 0 & ON , those are the values
robocfg is the program
port and jumbo are specific cmd's used to set the values above
you would need a script that knows what to do with those values
so yeah, much easier to add to services-start
I don't see the point in enabling Jumbo Frames on only one port of your switch. That means that any traffic forwarded from port 0 to any of the other ports will run into issues.
For jumbo frames to work properly, everything on the LAN segment must share the same settings.
Is there a way to adjust the mtu of the switch ports and save to nvram or is adding a call to ifconfig in a jffs script the only way?
Sorry yes that is what I would want to do enable on all ports on the LAN for jumbo. I would like it to be persistent so that a reboot will not require the commands to be manually run. Thanks!
I will give that a try Thanks!
LAN -> Switch Control
Set Jumbo Frames to "Yes" simply :)
Oops..I neglected to list an important piece of info, I am running in AP mode and do not have that option.
I also see that /jffs is read only and does not have a scripts sub-directory...I guess I can "chmod" it but don't want to break anything.
Thanks!
Thanks!
Not sure if the code will still initialize this properly while in AP mode (I didn't check), but give it a shot:
nvram set jumbo_frame_enable=1
nvram commit
reboot
Otherwise, see the Wiki on how to enable the JFFS partition, and then using user scripts.
the cmd you list above, would only change jumbo setting for 1 port not all ports
and if you want it on all ports
isn't there a check box in the gui for doing that
and I also agree with RMerlin
Jumbo frames are more trouble than it's worth
and it will probably negatively effect performance
edit: this is what happens when I respond from work
4 post happen, while I've started a response and working on something else
LOL
nvram commit
reboot
Thanks for all tour help I will give it a shot.
The nvram commands worked like a charm:D All LAN ports have jumbo frames enabled. I actually found better results with Jumbo frames reading/writing to a Netgear NV+ NAS. The biggest benefit was noticed with writes to the NAS.
Thanks so much for all your help Merlin! You rock...
