Sonos and IoT on RT-AX88U PRO
PaddyPDX
Hi, I don't have my new RT-AX88U Pro yet but was just reading about the IoT guest VLAN network it has, which sounds great. However, I was wondering if SONOS systems should be connected to IoT network. If so, then how would you fire up the SONOS app on your phone or computer? I already have issues when I use Google VPN and it can't find the SONOS system.
Does anyone have any advice on the best way to hook up a SONOS system with the ASUS RT-AX88U Pro router?
I saw this on the SONOS website but there appear to be a lot of articles out there that suggest otherwise and since ASUS has included a dedicated VLAN for IoT does anyone know if it does indeed work with SONOS?
Sonos products are compatible with most managed switches with some important considerations: Sonos products must be on the same VLAN as all devices running the Sonos app. Devices on separate VLANs will not be able to connect to Sonos products.
