System Error Message
Part of the Furniture
dont forget that you were using their midrange model. The higher range CRS 226 uses a different switch chip than the one you used and have had no issues bonding over different types of devices. In terms of layer 2 firewall and rules i actually leave that to the CCR because CPU based bridging has more features than switching. The CRS 226 uses a higher end qualcomm switch.
If the switch chip LAGG doesnt work with a particular type of bonding than it means other managed switches will not be able to work with it unless it uses the same type of bonding. You will find difficulty with getting non cisco equipment to work with cisco protocols because cisco keeps their stuff proprietary so if you want to use cisco features than you will have to get cisco hardware.
