Riekopo
I just got the TRENDnet TPL-420E2K powerline adapter kit. I previously have been using a TP-Link TL-PA511KIT. The TP-Link kit was two pronged, but the TRENDnet kit is three pronged. My router is an Asus N66U. I'm using Cat6a cables.
Previously my powerline adapters were plugged directly into outlets. However, when I got the new kit today I found that I can't plug in both the powerline adapter and the surge protector into the same outlet. The surge protector wires are too thick. I can only have one or the other plugged in. So I moved one powerline adapter to a different outlet, but in my room I only have one outlet with three prongs. My computer, monitor, and Xbox One all use three prongs. The only way for me to plug in everything I need is by plugging in the powerline adapter into the surge protector.
However, the manual says not to do that. The surge protector is a CyberPower CP1500PFCLCD. I don't understand why the surge protector wires are so thick and obtrusive. If they were normal sized then I would be able to plug the adapter and surge protector into the same outlet. Are there any surge protectors that have normal wires?
There's another outlet in my room just to the right that is two pronged. I guess I could switch it to a three prong outlet. Here's a picture of it. I don't know anything about that or if it's even possible.
