Emanuel Paul
Hello together
I've set up two openVPN clients (StrongVPN/PureVPN). Both work simultaneously. StrongVPN I use for my SmartTV and the NAS, PureVPN for one Computer. All other devices bypass any VPN. I managed this by setting up policy rules for the IP's of the devices what should use a VPN connection.
The problem is, that I often loose the public IP from PureVPN. Then I have to restart the service until next time.
I contacted PureVPN support. They told me, that it is not possible to have two active OpenVPN clients at the same time.
But I'm nearly sure, that I've read that it should be possible. But I only found a thread where one wanted to use several client setting to different server locations with one VPN provider. In my case it are two different provider.
Can anybody tell me, if the configuration I have set up should work?
