GT-AXE11000 can't handle more than 2 active VPNs
Owen
I am running 3 GT-AXE11000 routers with 3004.388.6_2_rog firmware. The problem that I have been having since I purchased the routers, is that I can't retun 3 or even 2 stable site/site OpenVPN connections.
Intially, I set an OPEN VPN site to site connection between the main router and the two other routers. This has worked but every 30 secods the connections froze.
After splitting the connections between OpenVPN connections between Server1 and Server2 on the router it has helped but was still unstable.
I ended up setting one, one way VPN connection between two routers. This works ok, however once a day, I have to reboot the hosting router. I purchased 3 expensive routers trying to get 4-5 active connections between each router, but I ended up not being able to have one stable connection. Needless to say, the internet connection is super stable on all 3 sites.
Is this normal behavior or am I doing something wrong that triggers this behavior?
