Two printers
_andy
I've connected two printers to AC68U(Firmware: 378.55), but for some reason only first one is enabled and working on 9100 port:
Is it possible to enable second one or print on it in some other way?
If you change their ports it'd work or you can use 2 routers. you have 2 hardware fighting to use the same resource so try to give them different ports or use different print services for each of them.
Could you point me to some documentation about changing printer port?
