USB Flash mounted read-only - resolved
Yah
Updated to the latest version 380.58 from 380.56.
A prompt appeared to reboot manually - turned power OFF/ON
Restarted, USB mounted read-only and my Entware services cannot start.
Created pre-mount script.
Jul 31 20:00:30 pre-mount: started [/dev/sda1]
Jul 31 20:00:30 e2fsck: ADATA_UFD: Adding dirhash hint to filesystem.
Jul 31 20:00:30 e2fsck: ADATA_UFD contains a file system with errors, check forced.
Jul 31 20:00:30 e2fsck: ADATA_UFD: The bad block inode looks invalid.
Jul 31 20:00:30 e2fsck: ADATA_UFD: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
Jul 31 20:00:30 e2fsck:     (i.e., without -a or -p options)
Any suggestions how to fix it.
