All,
I've had my N66 with .50 Merlin running for a while without an issue for a while now. Since the update I have had almost zero issue with the attached USB HDD (wall-powered). In the last two days, the drive has been unmouting itself - here is the log that could possibly be showing the issue. Any input would be great
May 17 02:13:20 kernel: usb 1-1.1: device descriptor read/64, error -145
May 17 02:13:20 kernel: usb 1-1.1: new high speed USB device using ehci_hcd and address 5
May 17 02:13:25 kernel: usb 1-1.1: device descriptor read/8, error -145
May 17 02:13:31 kernel: usb 1-1.1: device descriptor read/8, error -145
May 17 02:13:31 kernel: usb 1-1.1: new high speed USB device using ehci_hcd and address 6
May 17 02:13:36 kernel: usb 1-1.1: device descriptor read/8, error -145
May 17 02:13:41 kernel: usb 1-1.1: device descriptor read/8, error -145
May 17 02:13:41 kernel: hub 1-1:1.0: unable to enumerate USB device on port 1
May 17 02:13:41 kernel: usb 1-1.4: new high speed USB device using ehci_hcd and address 7
May 17 02:13:41 kernel: usb 1-1.4: configuration #1 chosen from 1 choice
May 17 02:13:41 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
May 17 02:13:43 kernel: scsi 0:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
May 17 02:13:43 kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
May 17 02:13:43 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
