Dismiss Notice
Welcome To SNBForums
Very Slow Web Interface
Discussion in 'ASUS N Routers & Adapters' started by ariesjunk, Jan 26, 2013.
  1. ariesjunk
    ariesjunk New Around Here
    Jan 26, 2013
    4
    The web interface of my router is very slow recently. I am using Chrome and Internet Explorer in Windows 8. I have already upgraded the firmware to the latest version from Merlin. Appreciate if anyone can give me some advices to fix it. Thanks.
  2. TonyH
    TonyH Very Senior Member
    Feb 19, 2012
    1,241
    Calgary AB Canada
    Cleared browser cache?
  3. ariesjunk
    Jan 26, 2013
    4
    The problem seems to happen with wired connection. The web interface is loading much faster with wireless connection. I am scratching my head now.
  4. Zulu0001
    Zulu0001 New Around Here
    Jan 27, 2013
    1
    Same thing is happening to me. Very strange
  5. Correlor
    Correlor Occasional Visitor
    Jan 28, 2013
    10
    Netherlands
    Hello,
    Check your virus scanner, mine (Avast 8 Beta under Win 7 and also Avast 7 under Win 8) did not like websites from local adresses anymore. Slow load and incomplete pages.
  6. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    18,626
    Canada
    If the issue is only with a wired connection, I would check these things:
    1) Make sure the cable is Cat 5e or Cat6
    2) Maybe try to replace the cable in case it's defective
    3) Make sure you don't have a packet size mismatch (i.e. don't enable Jumbo Frame, but leave everything to the 1500 bytes default)
    4) Make sure you aren't connecting both with wireless and wired at the same time on the computer
  7. -AndyH-
    -AndyH- Occasional Visitor
    Nov 19, 2012
    26
    Hi
    I am suffering the same problem since upgrading to Windows 8.
    Wireless is fine, wired most router pages don't load or half load with the spinning circle. If you hit refresh, sometimes the pages load immediately.
    Network is certified Cat6 with a Netgear 24 port managed gigabit switch.
    Tried with jumbo frames on/off, makes no difference.
    I am using version .260 if this helps.
  8. RMerlin
    Apr 14, 2012
    18,626
    Canada
    Could be your network interface not working properly under Windows 8. See if the manufacturer has any driver update.
    I have no issues myself since I updated my PC to Windows 8, using a Realtek Gigabit controler (onboard with my Asus P7P55D), running driver 7.53.216.2012.
  9. ariesjunk
    Jan 26, 2013
    4
    This problem is solved by downgrading my PC from Windows 8 to Windows 7. Does this means that N66U is not compatible with Windows 8?
  10. RMerlin
    Apr 14, 2012
    18,626
    Canada
    It's far more likely to be an issue with the wireless driver of your network card (which might not be fully Windows 8 compatible) than the router itself. My RT-AC66U and RT-N66U both work fine with my Windows 8 desktop. I would look for a driver update, and also make sure that whatever security software / firewall you run is also fully Windows 8 compatible.
  11. ariesjunk
    Jan 26, 2013
    4
    I restore the Windows 8 image and try to find out the cause of the problem once more time. I finally discover the culprit is the network shield of avast anti-virus program. I disable it and everything is normal now. Thanks for the help provided in the forum anyway.
Share This Page
