(Apologize if my English is bad, I am a French native speaker )
First of all, let me explain you the situation:
I switched from ATT to TWC and was surprised to discover that I was able to access up to 300 Mbps.
I decided to select the Extreme package and got 200 Mbps.
Currently, I have an Arris DG1670 (3x3:3@2.4 GHz and 3x3:3@5GHz MIMO with Beamforming) as TWC WiFi Cable Modem Router.
And as the Arris is not close to my desktop, I had two choices: use wireless or add a 16 ft cable.
Unfortunately, my wife was not agree to have a wire running all around the wall, so I had to use wireless.
I have been able to connect through wireless my Asus RT-AC66U to the Arris. Using speedtest.net, I was able to have (sometimes) 100-110 Mbps, but it is far from my maximal speed which is 200 Mbps if I use a wire.
My network was like this:
Arris<~~Wireless~~>RT-AC66U<--Wire-->Desktop
As the Asus couldn't work at full speed, I decided to "update" my network to have better wireless connection.
(Btw, a 14-16 ft cable will fix the problem but my wife will enrage, so I have to spend a lot of money to satisfy here. ).
I ordered on Newegg this WE a R6300v2 and an EX6200.
I know that the EX6200 is a bit too much, but I wanted something that could work if I move my office in another room and extend the wireless if needed.
I received everything yesterday, did the install and was very disappointed.
A speedtest from my Desktop using the install wasn't able to go higher than 20 Mbps !
The R6300v2 being close to the Arris, I cannot understand that.
I tested all the cable everything was fine.
By connecting the EX6200 to the Arris, I was able to get 100+Mbps but never reached higher than 120Mbps.
I sent an email to Netgear support to understand the issue (which should come from the R6300V2).
FYI, My link rate between the EX6200 and the R6300v2 is at 866 Mbps with a signal strength of -33 dBm (almost optimal).
If the issue is not fixed before this WE, I will probably return everything.
Here is my question, can I hope to find something that will allow me to be as close as possible from the 200Mbps using wireless ? What are the best options ?
Thank you for your help.
