sm00thpapa
What's coming after the AC3200 routers? Look for prices to be in the $400.00 range for the next class of routers.
My guess is, it will depend on how well these 270-300$ routers sell. If they sell well, then I guess we can expect a 320-340$ product in the coming months
This is a LARGE router I figured it would be bigger with the extra antenna. Like almost 2x the size of 66u and 68u. Unboxed mine late last night will mess with tomorrow.
Which router are you referring to?
Unfortunately, it's not that easy. You have to take into the equation the fact that overall performance will be drastically reduced if you have a set of mixed clients, e.g. using different wifi standards. If all of the 20 clients are 802.11ac, then your equation makes sense. But if you have 802.11a/g/n clients on the same radio as your 802.11ac clients, then bandwidth for the ac clients will be much slower because the router spends more time delivering data to the slower clients. Remember that only one client at a time can send/receive data...
So in that case, it's not necessarily true that more bandwidth on the router will result in more bandwidth for all the clients. Performance on Wifi networks is not just about total available bandwidth, it's a lot about how that bandwidth can be used.
Your 1300 mbit router will not deliver top speed to an 802.11ac client if at the same time a slow 802.11g client is transferring a large file, for example.
That problem will be taken care of eventually (by things like MU-MIMO and Xstream) though.
Good thing we don't have b/g clients on 5 GHz band. And a on 5ghz band is none existent.
The same is true for 802.11n clients on 5 Ghz as well. The point is, older standard clients will slow down your ac clients as long as they are conneced to the same radio.
It is not just mixed standards. Mixed capabilities within a standard also limit available bandwidth.Unfortunately, it's not that easy. You have to take into the equation the fact that overall performance will be drastically reduced if you have a set of mixed clients, e.g. using different wifi standards. If all of the 20 clients are 802.11ac, then your equation makes sense. But if you have 802.11a/g/n clients on the same radio as your 802.11ac clients, then bandwidth for the ac clients will be much slower because the router spends more time delivering data to the slower clients. Remember that only one client at a time can send/receive data...
So what? If you have 10ac clients, they will all run slow. There is a bandwidth limitation no matter how you slice it.
You were saying that the higher the bandwidth "on the box", the more bandwidth you will have for your clients. That's not true. Just pointing that out.
Thread starter | Title | Forum | Replies | Date |
P | Solved avoid wireless interference between 2 routers | General Wireless Discussion | 10 | |
C | American made routers and access points | General Wireless Discussion | 26 |
Welcome To SNBForums
