Why can't find the /jsff?
ac66ub1
Filesystem Size Used Available Use% Mounted on
/dev/root 33.9M 33.9M 0 100% /
devtmpfs 124.8M 0 124.8M 0% /dev
tmpfs 124.9M 1.3M 123.6M 1% /tmp
/dev/sda1 28.4G 184.2M 26.8G 1% /tmp/mnt/sda1
Look at above result of df -h,I cannot find /jsff?
Have you enabled and formatted the /jffs?...Options are listed on the administration section.
The reason is jffs unmounted,I don't know how to solve it, maybe a bug?
Jun 4 02:11:16 kernel: nf_conntrack_rtsp v0.6.21 loading
Jun 4 02:11:16 kernel: nf_nat_rtsp v0.6.21 loading
Jun 4 02:11:16 disk_monitor: Finish
Jun 4 02:11:17 rc_service: udhcpc 411:notify_rc start_upnp
Jun 4 02:11:17 rc_service: waitting "stop_upnp" via udhcpc ...
Jun 4 02:11:17 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
Jun 4 02:11:18 disk_monitor: be idle
Stock Asus Firmware:
