Wifi lost connection every day
Noam
Hello everyone I am new on this forum.
I bought this month the asus dsl-ac56u I use it with Wan connection.
I update for the last firmware.
Every day I lose my wifi connection, after few seconds it automatically reconect.
Who know about this problem?
Mybe it's the router problem?
What can I do to fix this?
Did you do a factory reset after the firmware update? No? :oops:
You should do it and configure manual settings on WLAN (do not touch the professional page on WLAN!) and test it!
With kind regards
Joe :cool:
Hi Jo,
Thanks for you quick reoly.
I do factory reset by the router inteface after update the firmware.
I can do another one.
I need make reset by the button or it's enough by the interface?
Just to know what is the right procedure to make hardware reset?
Noam
There is only ONE reset (regardless of the way you do it) - as discussed here.
Did you reconfigure the router manually after the reset (no restore of old backup settings!)?
I make reset and reconfigure it.
With my smartphone oneplus one, I think it's ok.
I have 2 laptop, one it's connecting without problem but the second it's a Sony it's connect and deconnect every few second.
Before the reset it stayed connected.
What do you think?
The wifi is not stable, I am disappointed from this product :(
I connect my old tp-link like switch with cable to my asus, the tp-link wifi working without disconnection.
Thanks for all informations.
I make a change in my wifi security.
for the moment it's working.
Thanks.
