I am starting a new thread since I believe this use case is becoming more common. Note that there may be other continuous parallel high bandwidth applications that would also benefit from this discussion.
I have several TiVo DVRs and several TiVo Mini STBs. My family all like different TV programs, so from 8pm-10pm a few nights a week, there could be 3 or 4 simultaneous HD video streams to phones or tablets from TiVo or Netflix. With family visiting over Christmas, this demand could increase to 5-7 simultaneous HD streams to phones, tablets, or laptops.
I currently have two AC1900 routers. An Asus RT-ac68p as a wireless router and a Netgear R7000 as an access point. These are recent additions to replace older N routers from Linksys and Apple.
I am seeking input on how best to configure the network that will keep coverage throughout the >3000 square foot 3 level home for all clients and handle 5-7 simultaneous HD video streams. I'm thinking of adding back the 802.11N APs while family is visiting to handle the additional bandwidth demand.
Some questions that come to mind are:
1) How many SSIDs? Will the load properly distribute on its own? or do I need to manually split the load via multiple SSIDs? Or is there a better way to split the load?
2) There are three 2.4GHz non-overlapping channels so I don't think I would run more than 3 APs on 2.4GHz, right? I notice most devices are using 5GHz by default.
3) How do I best use the 5GHz spectrum? There are 8 lower 20MHz channels and 5 upper 20MHz channels. On the AC routers, the upper channels provide greater range than the lower channels. How does the 20/40/80MHz selection impact performance on iPhones/iPads? Should I run all 4 APs on 20MHz channels in the upper 5GHz band or run 20/40 and use some of the lower band? I don't think I have any clients that can use 80MHz channels.
I will probably eventually work through these questions through experimentation, but it would be great to get some advice from those that have already figured this out.
Thanks!
Thanks!
