TheBlindKind
Hi, I'm in themarket for an Asus router that I can put the Merlin-Wrt software on. It's my understanding that Asus' AC routers are not backwards compatible to G, which would be bad for my setup as I still have some G devices thatI must be able to connect to the network. Would this be possible with an AC device or should I opt for an N router like the RT-N66U?
Secondly, I have a Linksys E4200 with DD-WRT installed on it that I use to force a certain batch of IP addresses to use OpenDNS regardless of what DNS is used on the client device. Will this firewall script work on Merlin?:
iptables -t nat -A PREROUTING -i br0 -s 192.168.1.100/26 -p udp --dport 53 -j DNAT --to $(nvram get lan_ipaddr)
iptables -t nat -A PREROUTING -i br0 -s 192.168.1.100/26 -p tcp --dport 53 -j DNAT --to $(nvram get lan_ipaddr)
I also have this firewall script to make sure one particular device with a static IP will not be blocked by OpenDNS:
iptables -t nat -I PREROUTING -i br0 -s 192.168.1.195 -p udp --dport 53 -j DNAT --to 209.244.0.3
iptables -t nat -I PREROUTING -i br0 -s 192.168.1.195 -p tcp --dport 53 -j DNAT --to 209.244.0.3
Finally, I have the following startup commands to set the maximum number of ports allowed and the hash size to match to make better use of the router's ram:
echo "131072" > /sys/module/nf_conntrack/parameters/hashsize
nvram set ip_conntrack_max=131072
And how about interferance mitigation?
I would really like to use Merlin instead of DD-Wrt if I get the Asus router because of the much simpler flashing process and thus less risk of router bricking, as well as peace of mind of having software that is much more dedicated to the specific router. I realize this is a lot to read and I thank you all for your time. My name is Tony.
