Win 10 Defender _ sandbox
The article didn't mention turning the sandbox off .
Run the command again replacing "1" with "0".
setx /M MP_FORCE_USE_SANDBOX 0
Really odd feelings here - for an AV to be effective, it really cannot be in a sandbox, lest it misses things that affect the WinNT kernel directly, or goes as Admin privs...
Only folks I would trust at that level, unfortunately, is Microsoft for Windows...
Err , it works, it is proven and it is Microsoft.
The processes are run at lowest privileges and prevent malware executing and compromising the system , the data stays within the sandbox.
https://www.microsoft.com/security/...-defender-antivirus-can-now-run-in-a-sandbox/
There are plenty of other write ups at Microsoft.
Tavis Ormandy described it as a game changer.
https://www.howtogeek.com/fyi/windo...-secure-sandbox-mode-heres-how-to-turn-it-on/
From what I understand, the antivirus is split in two. There's the part that accesses the system data to be analyzed (let's call it "the scanner process"), which then pass it along to an "analyzer process" that runs with low privileges, and which does the actual analyzing/unpacking/scanning task. So if an object passed to the analyzer tries to exploit a flaw in the engine (for example, if there was a flaw in the unzip engine), the only thing compromised then is that process that has no system privileges.
Yep - Defender is the only AV I would trust on Windows...
I installed it on a laptop and a desktop.
Any difference in the systems? Slowdowns or stalls? What kind of hardware specs on those?
I have noticed any difference yet but I have only used it for an hour or so. I installed it right after the Microsoft Win10 update tonight.
They are both Dell's with I7 CPUs.
