1Gbps but can only achieved 290+Mbps on AC87U
oric1
Need advise please.
How come when I connect my PC direct (wired) to the Optical Network Terminal (ONT), I'm getting 900+ up & down but when I'm connect via PC -> ASUS 87U -> ONT, I'm only getting 290+ up & down.
I am on the latest Merlin's 378.53 firmware and my NAT Acceleration is set to Auto.
Is there anything else that I need to set on the router? Thanks.
PC -> ONT
Direct_zps2ocov4cr.png~original
PC -> AC87U -> ONT
to%20ASUS_zpsbjlorvrk.png~original
Don't expect these consumer routers to be able to route at 1gbps. Your PC is likely a lot more powerful. Things like the firewall all add additional overhead for the relatively weak cpu in the router.
We use $50k routers for 1gbps routing. You may be able to get 1gbps if you convert a pc into a router.
my AC68u can only achieve 150mbs initially on a 500mbs subscription.
A factory reset bring it back to full working condition.
also look into your iptables list as the table list may hinder NAT Acceleration.
My bad. Initially I limit my QoS to 300Mbps. After removing the limits, I'm able to go beyond 900Mbps.
Thanks to everybody who replied :)
