2.4Ghz Wireless disconnects unstable and reproducible
Ever since I upgraded to SDK6-based firmware, I have noticed that certain 2.4 GHz devices in my house will occasionally disconnect and be unable to reconnect until either they are rebooted (or their network interfaces are reset) or the router is rebooted. This typically happens only after the router has been running for at least a day or two.
I'm not sure if this is related, but generally, after a day or two of uptime, I'm also seeing the following message pop up in the router's log every couple of hours:
kernel: eth1: received packet with own address as source address
This occurs on both ASUS' stock firmware and Merlin's custom builds.
Does anyone have any idea what might be going on?
EDIT: Forgot to mention: this is on an RT-N66U.
I have observed the exact same behavior only in Access Point mode on multiple AC66U units (so it's possibly not the hardware). It is reproducible on a number of stock and Merlin firmwares. I have a couple of additional facts for others to see if there is a commonality.
- Reproducible on two separate AC66U units tried so far,
- Occurs reproducibly after a few hours of working fine on Asus stock firmware revs: 3.0.0.4.374_130 , 3.0.0.4.374_726 , 3.0.0.4.374_979 and Merlin 3.0.0.4_374.33 and 3.0.0.4_374.34
- The 5GHz signal will eventually go unstable also given a day or two
- ASUS 2.4Ghz is on channel 11, 20Mhz only
- On an ATT UVERSE based network with a TWOWIRE 3800HGV-B gateway, the 2.4Ghz signal from this gateway is on channel 1, hardware version 2700-100531-006, Software Version 6.9.1.42-plus.tm
- Even if the AC66U goes unstable, it is accessible via LAN and shows the other devices on the LAN correctly through the AC66U GUI
- The WiFi signals are still being transmitted when the system goes unstable.
- Normal connection speed is a rock solid steady 7.5MB with a 48ms +/- 3ms ping to outside but when unstable the speed is highly variable aroud only 800Kb with ping times of several hundred ms if one can still make a connection.
The following message is observed in the log even before the instability occurs and so far always in conjunction with instability:
- Same or differing SSID's from base UVERSE router doesn't matter.
- Letting the unit automatically get its IP address or manually entering it as an Access Point does not make a difference. It will go unstable under both conditions.
- There is nothing plugged into the routers output ports. Plugging the LAN into the WAN socket or the output ports doesn't matter. It will go unstable either way.
- We have used other vendors WiFi routers in the same physical location as Access Points without issue so I doubt it is interference from neighboring WiFi signals.
- Once it goes unstable, rebooting everything doesn't necessarily fix the problem every time! (Still trying to understand if possibly the UVERSE Router is temporarily corrupted by this AC66U instability.)
- No problems observed in Router or Media Bridge mode
Is there anyone else with anything in common?
