378.50_ta Traffic Analyser Question
jgrove
Hi All,
I must be missing something but i cannot get the Traffic Analyser to work on my AC87.
I have enabled it and the router updates but even after 2 days theres nothing to report ?!
I must be missing a setting?
Any assistance appreciated,
Regards
Hi All,
Regards
Have you tried deleting
/jffs/traffic.db
From the shell prompt? Not done that i'll try, Thanks
Yes... although I personally rarely need to open a SSH/TELNET command prompt as I use WinSCP.. to create/edit/delete and execute the scripts etc.
