[380.57] IPv6 Losing IP Info On Config Update
Veldkornet
Hey guys,
I have 380.57 on my RT-AC87U.
So my ISP gives out an IPv6 to my cable modem. I then have my 87U behind the modem which gets an IPv6 automatically. In general, all the IPv6 traffic seems to work fine, but if I update anything (such as the IPv6 DNS servers for example) all the IPv6 addresses, gateway etc are all gone and stay removed indefinitely until I reboot the router.
After a reboot, it gets its IPv6 ip again and everything works normally again.
Anyone else having this problem?
You don't have to reboot it. In my case, which is exactly the same like yours, unplugging the WAN cable and plugging it in after 5 seconds or so makes the router get its IPv6 address. I have not found a better way to "fix" it.
