384-20308 update 01FEB18
bbunge
Part of the Furniture
My RT-AC66U_B1 reported a firmware upgrade this morning. As before, going to Administration - Firmware Upgrade gave me the upgrade progress bar with no upgrade at the end. Using the Android app also failed the upgrade. I downloaded the 384-20308 upgrade file, rebooted the router, went to the Administration - Restore/Save/Upload Settings tab then back to the Firmware Upgrade tab, clicked the Upload link, found the file and the firmware upgrade ran successfully! I had also cleared the Firefox cache and offline data. Am using Firefox ESR 52.6.0 64 bit.
As in all things computer, your mileage may vary! Best of luck!!!
