Skynet 386 GitHub builds does not work with Skynet
Blacklistedcard
Compiling my own firmware builds from the 386 branch. The model number is not displayed when you try to launch skynet. Running firewall at the command prompt errors out.
Router Model;
Skynet Version; (01/12/2020) (358a0e65e85afa8425897a993eb84b8c)
iptables v1.4.15 - (eth0 @ 192.168.1.1)
ipset v7.6, protocol version: 7
IP Address;
FW Version; 386.1_beta3-g1b79675d07 (Dec 28 2020) (4.1.51)
Install Dir; /tmp/mnt/sda1/skynet (50.6G / 56.2G Space Available)
/jffs/scripts/firewall: line 1: arithmetic syntax error
admin@RT-AX88U-5918:/tmp/home/root#
Run the script like this to get debugging output:
Bash:
sh -x /jffs/scripts/firewall
Note that compiling your own firmware is missing many components in the stock Asus or RMerlin fork.
Unless you're only testing for something extremely specific, it is not a build to base a router on for actual use. Depending on what settings/features you want to lose, of course.
My reply is OT, but it’s very sad that ASUS had to take this drastic step to neuter the source code in this new branch. I understand it’s due to all the illegal forks and mis-uses of the proprietary Trend Micro stuff, but it really kills the feeling of an open source firmware.
Bash:
I think it's failing on this code... It's Merlin beta branch for the 386 firmware.
Extended_DNSStats() {
case "$1" in
1)
if [ "$lookupcountry" = "enabled" ]; then
country="($(curl -fsL --retry 3 --connect-timeout 3 -A "ASUSWRT-Merlin $model v$(nvram get buildno)_$(nvram get extendno) / $(tr -cd 0-9 </dev/urandom | head -c 20)" "https://api.db-ip.com/v2/free/${statdata}/countryCode/"))"
if [ -z "$country" ]; then country="*"; fi
fi
Here is the debug output...
# Router Firewall And Security Enhancements #
# By Adamm - https://github.com/Adamm00/IPSet_ASUS #
# 01/12/2020 - v7.2.3 #
+ export LC_ALL=C
+ mkdir -p /tmp/skynet/lists
+ mkdir -p /jffs/addons/shared-whitelists
+ ntptimer=0
+ nvram get ntp_ready
+ [ 1 = 0 ]
+ [ 0 -ge 300 ]
+ grep -vE ^#
+ awk {print $1}
+ grep+ cut -c 11-
-ow skynetloc=.* # Skynet /jffs/scripts/firewall-start
+ skynetloc=/tmp/mnt/sda1/skynet
+ skynetcfg=/tmp/mnt/sda1/skynet/skynet.cfg
+ skynetlog=/tmp/mnt/sda1/skynet/skynet.log
+ skynetevents=/tmp/mnt/sda1/skynet/events.log
+ skynetipset=/tmp/mnt/sda1/skynet/skynet.ipset
+ date +%s
+ stime=1609436264
+ [ -z /tmp/mnt/sda1/skynet ]
+ [ ! -d /tmp/mnt/sda1/skynet ]
+ nvram get wan0_proto
+ [ dhcp = pppoe ]
+ nvram get wan0_ifname
+ iface=eth0
+ [ -z ]
+ Load_Menu
+ . /tmp/mnt/sda1/skynet/skynet.cfg
+ Display_Header 9
+ printf \n\n===================================================================================================n
+ echo Router Model;
Router Model;
+ Filter_Date
+ grep -m1 -oE [0-9]{1,2}([/][0-9]{1,2})([/][0-9]{1,4})
+ + awk {print $1}
md5sum /jffs/scripts/firewall
+ echo Skynet Version; (01/12/2020) (358a0e65e85afa8425897a993eb84b8c)
+ iptables --version
+ nvram get lan_ipaddr
+ echo iptables v1.4.15 - (eth0 @ 192.168.1.1)
+ ipset -v
+ nvram+ Is_PrivateIP
+ grep -qE ^(0\.|10\.|100\.(6[4-9]|[7-9][0-9]|1[0-1][0-9]|12[0-7])\.|127\.|169\.254\.|172\.1[6-9]\.|172\.2[0-9]\)
get wan0_ipaddr
+ nvram get wan0_ipaddr
+ nvram get ipv6_service
+ [ dhcp6 != disabled ]
+ nvram get ipv6_prefix
+ nvram get ipv6_prefix_length
+ echo - (2607:fea8:a7c0:f::/64)
+ echo IP Address;
IP Address;
+ nvram get buildno
+ nvram get extendno
+ + uname -v
awk {printf "%s %s %s\n", $5, $6, $9}
+ uname -r
+ echo FW Version; 386.1_beta4-gde99bc07fd (Dec 31 2020) (4.1.51)
+ df -h /tmp/mnt/sda1/skynet
+ xargs
+ awk {printf "%s / %s\n", $11, $9}
+ echo Install Dir; /tmp/mnt/sda1/skynet (50.7G / 56.2G Space Available)
+ [ -n ]
+ [ -n ]
+ [ -f /tmp/skynet.lock ]
+ sed -n 2p /tmp/skynet.lock
+ [ -d /proc/29954 ]
+ echo
+ Check_Connection
+ + grepgrep -qvE -E ^#
start.* # Skynet /jffs/scripts/firewall-start
+ [ -w /tmp/mnt/sda1/skynet ]
+ Check_Swap
+ grep -qF file /proc/swaps
+ + crugrep l
-c Skynet
+ [ 2 -lt 2 ]
+ Check_IPSets
+ ipset -L -n Skynet-Whitelist
+ ipset -L -n Skynet-Blacklist
+ ipset -L -n Skynet-BlockedRanges
+ ipset -L -n Skynet-Master
+ ipset -L -n Skynet-IOT
+ [ -n ]
+ Check_IPTables
+ [ = all ]
+ [ = inbound ]
+ [ = all ]
+ [ = outbound ]
+ nvram get sshd_enable
+ [ 2 = 1 ]
+ [ = enabled ]
+ [ = enabled ]
+ [ -n ]
+ [ = enabled ]
+ [ != 1 ]
+ Print_Log minimal
+ oldips=
+ oldranges=
+ grep -Foc add Skynet-Black /tmp/mnt/sda1/skynet/skynet.ipset
+ blacklist1count=49994
+ grep -Foc add Skynet-Block /tmp/mnt/sda1/skynet/skynet.ipset
+ blacklist2count=1865
+ unset fail
+ Check_IPTables
+ [ = all ]
+ [ = inbound ]
+ [ = all ]
+ [ = outbound ]
+ [ 2 = 1 ]
+ [ = enabled ]
+ [ = enabled ]
+ [ -n ]
+ [ != outbound ]
+ iptables -xnvL PREROUTING -t+ raw
grep -Fv LOG
+ grep -F Skynet-Master src
+ awk {print $1}
+ hits1=
+ [ != inbound ]
+ iptables -xnvL PREROUTING+ -tgrep raw
-Fv LOG
+ grep -F Skynet-Master dst
+ awk {print $1}
+ iptables -xnvL OUTPUT -t+ raw
grep -Fv LOG
+ awk {print $1}
It looks like the addition in this line is the cause:
Bash:
hits2="$(($(iptables -xnvL PREROUTING -t raw | grep -Fv "LOG" | grep -F "Skynet-Master dst" | awk '{print $1}') + $(iptables -xnvL OUTPUT -t raw | grep -Fv "LOG" | grep -F "Skynet-Master dst" | awk '{print $1}')))"
Try breaking down each command to see which one doesn’t result in a number.
Bash:
Bash:
