4g ac55u can't connect to the admin page (error_status).
doudoufr
hi
i just bought a asus 4g ac55u.
I try to configure it, but when i change some parameters, it log me out, and then, no way to login anymore.
http://192.168.1.1/Main_Login.asp?error_status=1&page=index.asp
As you can see, in the address, there is the "error_status". i enter my login info on this page, but when i click on connexion, nothing happens. I try with Edge, Firefox, Chrome....the same !
So, i reset, and reset again, and try configure it, and then boum ! log out....with no way to login again. So reset again.
I also download the firmware and reinstall it....but doesn't change anything !
So how do I do to connect to this f*cking admin page ?
I just manage to change the login / password, but after that and a few things, but if i click on "apply", bouuum....can't login again ! (i can connect with telnet, but this is not what I want...and I don't know what to do with this anyway !)
So what's wrong with this one ?
Do I miss something ?
How could I get rid of this ?
Do you know any solution ?
229€ and it's not working !!!! I'm pissed !
sorry for my english, i'm French ! :)
well.....i just change the password.....for the admin.that's all !
if i disconnect and try to reconnect after that....no way....
the login page do....NOTHING !
Thanks, but....did you read my post ?
Avoid any esoteric characters in your password, they don't always get properly passed through the webpage. Stick to alphanumerics, and basic symbols such as "-!_".
"% and $" can cause problems.
already tried that. But it seems that the login webpage do....nothing.
i can't click on the connexion button. it is not active. "enter" do nothing also.
i'm lost and disapointed !
If the buttons don't work, then quite possibly something is causing a Javascript error. Open the web browser console and look for any Javascript error.
yes i think there is
Main_Login.asp?error_status=1&page=index.asp:34 'webkitAudioContext' is deprecated. Please use 'AudioContext' instead.
Main_Login.asp:231 Uncaught SyntaxError: Unexpected identifier
Adguard Assistant Beta?rand=635938916273409401:70 Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
Main_Login.asp?error_status=1&page=index.asp:322 Uncaught ReferenceError: initial is not defined
3Main_Login.asp?error_status=1&page=index.asp:351 Uncaught ReferenceError: login is not defined
but what should I do ?
see the screen capture.
Click on that "MainLogin.asp:231" to see the content of that line. That will tell us what is breaking the page.
well it seems that my unit is faulty. I can't even have the wizard config correctly now.....:-( :-( :-(
Try disabling any plugs/extensions (Adblock, etc...) and see if that helps...
well well well
you will not believe it !
After searching for another router on amazon, i see that someone who bought an asus router, but not the same one, has the same config page as mine (without nothing). And then, he explains that the browser need to be in english....Otherwise, problem with the webpages of the router.
In a last chance, i said to myself, well...let's try it !
AND....AND .....AND......it seems to work !!!!!!!! i can now configure the router, and go to every webpages of the config !!!
UNBELIEVABLE !
Mother F*cker !
What the hell !!!!
Holy Crap !
F*ck
Kind of UNACCEPTABLE from Asus !!!
oh noooooo !
i speak to quickly !
it has worked for 10min....and now...Still the same !
no webpages !
i have definitely a faulty unit ! :confused::confused::confused::(:(:(
You really need to check the content of that line as I wrote in my last post. There's a good chance your issue comes from another device that has an invalid hostname.
even with no other device plug in, just the router and my computer, it doesn't work
Also, as I wrote, i managed to pass the login screen and configure it for.....10min, but after that, boum ! the webpages go wrong again.
So don't bother.
I'm sending it back and i will buy a huawei instead.
thanks for the help anyway.
I have now had this happen in Safari 10 running macOS Sierra. The error I received is below. Any thought on this?
The error states Unexpected CSS token: #FFF 9 for the Main_Login.asp:80
