What is the latest wisdom on getting the 5Ghz (Guest Wifi) band to actually work on the GNP Nodes, using AiMesh (in addition to the 2.4Ghz band).
I do not wish to create APs atm.
My Guest Network (GNP) is working, but clients (iPhones and iPads) all seem to be served 2.4Ghz only (on Guest) and not 5Ghz w.e.o.
(a) when connected to the MAIN router (where they can get EITHER)
OR
(b) if I connect the devices AT the Node to the Primary Wifi (subnet 47) they get 5Ghz straight away i.e. NOT Guest Wifi.
This suggests that for 2.4Ghz the Wifi propagates MAIN and GUEST but for 5GHz it propagates just the MAIN Wifi to each node?
See example below for XD6 Annex Node, which shows on subnet 47, there is a 5GHz connection; but on 52 (Guest) only 2.4GHz.
Ths pattern is repeated on all nodes. Very frustrating.
In the past (forum search) folks have variously said (and I have tried all these):
- Update FW MAIN and Nodes
- "YES" DO use Ethernet Backhaul Mode Setting
- "NO" do NOT use Ethernet Backhaul setting (in EITHER place, System Settings "Ethernet Backhaul Mode" Management, "Backhaul Connection Priority", use Auto
- Switch on and off the 5Ghz Band on each node, under "Enable Radio"
- Reboot Node, reboot main, reset nodes, re-attach.
Setup:
Just frustrated,
ASUS Docs:
"This feature can only be configured on the AiMesh router. Guest network is currently designed to allow the first set of each band (2.4G, 5G, 5G-1) available to the AiMesh node. Only one set is available for each band. "
Cryptic as all get up, but I read that BOTH 2.4G and 5G (one SET) is available to the node.
So absent IoT 24 (which i KNOW does not get to the node) at least I should see 2.4Ghz AND 5Ghz GUEST Wifi BOTH getting there, right (as well as Main 2.4 and 5 of course)?
OR
Setup:
- RT-AX86U Pro Main, 2 x XD6 and 1 RT-AX58U Nodes
- Merlin 3006.102.5 on Main, latest stock FW (3.0.0.4.388_23813) on XD6s and 3004.38.10 beta on the RT-AX58U Node
- Two GNP Setups, GUEST (2.4GHz+5Ghz) and IoT (2.4 Ghz only)
- GUEST on own VLAN 52, IoT uses MAIN subnet 47.
- For Guest I selected ALL Nodes for AiMesh. Once I had done that IoT was limited to Primary Router only (X's) as expected, non 3006 GNP Nodes.
- Ethernet Backhaul on all nodes but Ethernet Backhaul Mode OFF (AiMesh System Settings) AND
- WPA2/WP3 on the Guest Wifi
- WPA2 on the IoT Wifi
- The Nodes all connect just fine (Ethernet Backhaul is great).
Just frustrated,
ASUS Docs:
