I believe it was on dongknows.com for exampleWhere did you read that, I've always read that mesh nodes should be stock?
Instead of some dong guy, why don't you get it from the source:I believe it was on dongknows.com for example
Had the opportunity to do a full factory reset on one of my two networks as I am now there and it seems to have fixed issues that were being reported.Adding my name to the list. 105 on my mesh nodes simply wasn’t working. Clients (plural) which were absolutely fine on 104 just wouldn’t connect on 105. Reverting fixed the issue.
FYI I've never really had any issues with AiMesh nodes and I've never run Merlin on any nodes so don't be so quick to come to the conclusion that's the root cause. What you're describing sounds suspiciously like your main router supports Guest Network Pro but your nodes aren't working with it correctly. We went deep down the rabbit hole on this in a different thread. To put it bluntly, GNP is a hot mess.I guess, the issue comes because runs merlin and nodes don't.
If the managed switch hasn't been configured for VLANs at all for the ports the node(s) is/are connecting to it shouldn't affect GNP unless it's behaving in a non-compliant manner and messing with the VLAN ID information in the packets that are passing through it; managed switches are just like unmanaged switches if you aren't using any of the extra features. Out of curiosity, what happens if you connect to a node via WiFi on the main/regular WiFi instance and not one of the GNP WiFi VLANs? Does the device get an IP address?@Seth Harman Thanks for your answer.
Your're right, I guess the issue is there is a managed swtich in between. I've added the vlan 52 to the ports that connect the router and the node, but it seems there is something else to configure, because it doesn't work yet.
If you have manage switches in the mix, the following Asus Guest Network Pro support document may (or may not) be relevant.Well, my issue is clear... I need to configure the managed switches... I have two managed in between, both running as L3... I very noob with networking, perhaps changing to L2 would be easier.
www.snbforums.com
I've explained this near the end of that thread: The only reason to use managed switches in conjunction with Guest Network Pro is to add wired clients to your GNP VLANs in cases where your AiMesh nodes don't support wired VLAN tagging and you cannot/choose not to connect these wired clients directly to the main router. Managed switches do absolutely nothing to help with GNP not properly giving out IP addresses from VLAN IP blocks to wireless clients connecting to AiMesh nodes. If the wireless clients connecting to your AiMesh nodes are not receiving IP addresses from a given VLAN IP block the issue is very likely to be the AiMesh nodes not properly supporting GNP and that's what you need to be looking into, and you'll be wasting your time trying to use a managed switch to fix this issue because it won't.Homework for tomorrow
Switch capabilities of AiMesh Nodes?
Most likely the connection type in GUI is for Asus devices with MoCA or PLA integrated options. I've seen some sold in other countries. In your case MoCA is a transparent bridge with Ethernet end points. I would be surprised if Asuswrt is actually seeing it. Link up/down monitoring is indeed...www.snbforums.com
I'm saying managed switches only provide the ability to VLAN ID tag *WIRED* traffic so you can direct the traffic to any VLANs you've created using Guest Network Pro. For example, I have a Hue lighting hub and they connect to a network via Ethernet. I wanted all my Hue lights on the IoT VLAN that I configured using GNP so I connected the hub to a managed switch and configured that switch to VLAN ID tag all traffic coming from the port the Hue hub is connected to using VLAN ID 53. This causes the Hue hub to get an IP address from the 192.168.53.x block and makes it part of that VLAN.Thanks for your answer.
I didn’t install the managed switches because they are coolthey are there 3-4 years ago… now with the GNP I’m having this issue… so, are you telling me it never won’t work ?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
